Probably going to install GSC S1 cams myself, limp to the dyno?
I am going AMS stage 3. I live about an hour away from AMS. I want to save money by doing the install myself, and I do my own work anyways. My question is, with the GSC S1 cams, will I be ok if I stay off boost and limp to their shop? Thanks for any help guys.
you will be fine. just make sure the cams go in the right way and timing is good. bleed your lifters and do the auto lash adjusters as mentioned above. rev up to 3000 and hold it there for 15 seconds and then let it idle for 15 seconds. repeat this process a couple of times till the ticking stops.
MadBoost23
Lancer Engine Management / Tuning Forums
Jun 10, 2015 11:57 PM
