Evo 8 engine tick / oil light, please help!!!
Old Nov 13, 2008 | 08:05 PM
TalonTuner4G63's Avatar
Is it a "TIC" or a "KNOCK"?
Old Nov 13, 2008 | 08:11 PM
EatSleepBoost's Avatar
the light could be because of a oil pressure sensor going bad. i just replaced mine and many people have problems with them.
the tick may be just your injectors or normal lifter noise if ur not familiar with ur car.
thats being optomistic. if its not that then u have some horrible oil pressure and prob need a new oil pump
Old Nov 13, 2008 | 08:14 PM
R/TErnie's Avatar
put a mechanical oil pressure gauge on your car. Check your pressure cold idle, hot idle, hot cruising at 4k rpms. report back.
I'm putting my money on spun rod bearings. I bet you have little to no oil pressure. Your lifters are making noise because there is no oil getting to them...your oil pressure light is flickering because you're on the threshold of the light turning on. Good luck! I would get a hold of the seller asap.
Old Nov 13, 2008 | 08:26 PM
wevo1985's Avatar
what weight oil are you using? this could be happing if your using 5w30. its not thick enought when the oil is warmed.
Old Nov 13, 2008 | 08:31 PM
advanblackevo8's Avatar
yea i think it is the oil pump but you only here the noise in the valve train. i spun bearings in my mustang after a shop messed the engine up and clogged the oil pump and beleive me i know what that sounds like and its definatly not a spun bearing or bearings. when the oil was changed i saw no metal at all. if the oil pump is bad why when i disconected the battery and reconnected it the light went off and the noise stopped. thats what is confusing me. why is it only happening after i changed the oil and the battery?
Old Nov 13, 2008 | 08:35 PM
i am going to hook a guage up tomorrow and see. yea i was told to use 5w30 mobile 1 but there is 10w30 in it. i was told by a few people that it should use 5w40 or 20w50 ( is this true)
Old Nov 13, 2008 | 08:39 PM
wevo1985's Avatar
stick with 10w30. i have no problems with it.
Old Nov 13, 2008 | 08:41 PM
do you think cause i have 75k miles it need a thicker oil
Old Nov 13, 2008 | 08:44 PM
is it ok to drive at 4000 rpm with the car make that noise and the oil light on. i am worried i will blow the engine if its something serious.
Old Nov 13, 2008 | 08:50 PM
its a tick and you can hear it in the valve train .
Old Nov 13, 2008 | 09:13 PM
chargespeedMR's Avatar
5w30 or 10w30 is perfectly fine for a stock motor. If you have a built motor, some people use 20w50.
No
If you drive the car and you are around or over 4k rpm and oil light is still on...then shut her down.
Old Nov 13, 2008 | 09:30 PM
C6C6CH3vo's Avatar
Put recommended oil in there with mitsubishi filter and see if it goes away. Properly check level after filling by running engine till warm, parking on a level surface (garage) letting it cool, then checking. Ticking when not at idle with an oil light can mean something ugly. Like worn bearings causing lack of pressure in the head.
Classic nuisance lifter tick usually happens at idle and goes away off idle
Old Nov 13, 2008 | 09:56 PM
well i am going to chane the oil pressure sensor tomorrow and check the oil pressure and will let you guys know what the result is.
Old Nov 13, 2008 | 09:57 PM
yes you can hear the ticking at idle
Old Nov 13, 2008 | 10:04 PM
WickedIXMR's Avatar
Heres my recommendation....If you dont know what the hell you're doing, take it to a god damn shop.
