Crazy noises under de-acceleration (vid inside)
Old Nov 14, 2008 | 09:50 PM
Slovo's Avatar
hmm id have to bet on one of your diffs, either the front one in the trans, or the TC. If you have access to a lift, lift it up and look around and see where the noise may be from! Good luck with everything! oh somtimes clutches make these noises as well, but only from twin discs from my experience!
Old Nov 14, 2008 | 09:52 PM
revvin9k's Avatar
It's gotta be the front one since I just did the rear one. I knew this day would come some time, I just wish it wasn't so close to the day I changed my diff. And I wonder why my wife hates my cars.
Old Nov 14, 2008 | 10:00 PM
Slovo's Avatar
haha yea i get it all the time from my girlfriend ha! Oh well! goodluck again!
Old Nov 16, 2008 | 03:26 PM
RSGuy's Avatar
check your flywheel bolts. my flywheel bolts managed to come loose after a clutch install. it was making a similar noise. hope this helps.
Old Nov 16, 2008 | 03:30 PM
RSGuy's Avatar
Oh yeah I forgot to add, you should stop driving your car until you get it sorted out. You could be marring/warping your crankshaft.
Old Nov 16, 2008 | 04:54 PM
brandEvO's Avatar
Gotta be the diff. This is probably way off, but a cheap thing to check out. But try bleeding your ACD lines.
Old Nov 16, 2008 | 07:49 PM
Murf's Avatar
I had a similar noise and I could feel the vibrations. check the drive shaft again buy look at that large damper with all the bolts in it...check the seal and make sure that it has not given out. look where the drive shaft goes into it.
Old Nov 17, 2008 | 05:20 AM
revvin9k's Avatar
I had this noise w/ the Exedy Single, and after with the Exedy organic install. I do not think it is clutch/flywheel related.
Old Nov 17, 2008 | 05:21 AM
revvin9k's Avatar
I have an 8.
Old Nov 17, 2008 | 07:40 AM
gsrboi80's Avatar
Normal Man. My evo and every other EVO I have ever been in has made hellish decel noises. Mine for all of its life. 107k on her now
With a clutch and Flywheel combo the noise and vibration will increase greatly. I thought every evo owner knew this as normal.
Mitsu even has a Tech Bullten about it
Page 3 has the bulletin
https://www.evolutionm.net/forums/sh...leration+noise
No worries boss drive it like you stole it. Call Shep and/or TRE they'll confirm the decel noise
Old Nov 17, 2008 | 07:53 AM
wevo1985's Avatar
i sounds like you have solid mounts in your car. eather motor or the rear diff mounts. you bought this car making the noise? i would look into what else is added to the car
Old Nov 17, 2008 | 01:44 PM
revvin9k's Avatar
All I have is a AMS front motor mount and the Whiteline diff carrier bushings, nothing to casue all the ruckus. The noises were there and I had made a post a long time ago about this.
Several said it was harmonics from my exhaust etc. There is some sort of problem some where. I have been talking back and forth with Jon at TRE, ( I have his Maxx Lock diff on now) and he is also perplexed.
I'll take the suggestion as they come. Thanks.
Old Nov 17, 2008 | 02:07 PM
Lumpskie's Avatar
I just replaced my clutch with a Fidanza 3.2 and started getting these noises. (quieter and without vibration) Checked most the stuff listed above and figured that it was just noise associated with the new clutch. I'm glad to hear that other ppl have run into this. I figured it was normal, but the confirmation really helps
Old Nov 17, 2008 | 02:09 PM
Lumpskie's Avatar
From the other thread...
07/15/2003 TT-95-00-003 WHINING SOUND ON DECELERATION
08/12/2003 TSB-03-00-014 NORMAL NOISE CHARACTERISTICS (LANCER EVOLUTION)
Old Nov 17, 2008 | 02:46 PM
evoixmr1818's Avatar
sounds wierd
