Lean Idle 18.4!!!!!
Old Nov 17, 2008 | 10:09 AM
gsrboi80's Avatar
Mine does it warm or cold. Injectors are scaled fine with in 5%. Idle and cruise. Maf scaling did not make a difference either.
I don't really care too much though the car is going to get a stand alone at some point. The leaner idle wont hurt the car. As long as it's fueling properly in higher load areas and at higher piston speeds it'll be fine
Old Nov 17, 2008 | 10:24 AM
Mellon Racing's Avatar
Originally Posted by GoturV8
okay I found 2 small exhaust leaks, and fixed them, but still the car a/r falls to 18.4, after a while I decided to uplaod the bas map that my tuner sent me, and when I did the car start to idle fine and the a/r reads 14.7-15.3.
So if am not wrong I think it's the tune, am gonna check it with my tuner and see if there's something he forgot.
If you guys got any suggestion please let me know thanks
if you rolled back to the original tune after fixing the exhaust leaks and the AFR started behaving then you've found the solution to the problem...
Old Nov 17, 2008 | 10:34 AM
gsrboi80's Avatar
Yes this is true I must have missed that
Old Nov 17, 2008 | 10:44 AM
GoturV8's Avatar
Okay, I decided to attach 2 logs, both with the car idleing for 12min.
And guys if read what I said in first post, the car idle like normal on cold start, but once the car warms up it falls to 18.4, you can see that in one of the log that I attached
Guys please check them and tell me what you think
Thanks
File Type: zip
File Type: zip
Old Nov 17, 2008 | 10:48 AM
I think you need to give your tuner a chance to figure it out...sounds like you've had some mechanical issues which caused him to waste his time, now those issues are fixed and the tuner needs time to start over.
Old Nov 17, 2008 | 08:31 PM
GoturV8's Avatar
I am giving him a chance, he's one of the best tuner, I just want to know if am missing anything eles
Old Nov 18, 2008 | 10:27 AM
maybe so but it makes him look bad when you make a thread like this to second guess him....just FYI
Old Nov 18, 2008 | 10:37 AM
typac69's Avatar
hes asking for help from anyone else. if the tuner is busy or something and cant answer 24/7.. All he wants is other input I dont think hes putting the tuner down at all.... Hope you get everything solved and running Good...
Old Nov 20, 2008 | 01:28 AM
GoturV8's Avatar
Mellon am only trying to find if there's a problem with my car, and thank god I solve it
Thanks every one for helping me out
4WS is the man he was able to let me find, and fix the problem, now we're doing cruising logs, and soon some power is on the way.
Wish me luck guys, and thanks again to everyone
Old Nov 20, 2008 | 05:16 AM
gsrboi80's Avatar
So what fixed it
Old Nov 20, 2008 | 11:33 AM
Originally Posted by gsrboi80
So what fixed it
Old Nov 22, 2008 | 10:36 PM
GoturV8's Avatar
it was the tune, we went back to the base map, did a idle log than 4WS sent me another map and everything went back to normal, the guy just never gives up
Finished scaling the injecotrs now doing some pulls
Fast_Freddie
Oct 30, 2023 01:56 AM
Gary@MellonRacing
May 13, 2011 07:07 PM
BoostLover99
Sep 8, 2010 03:49 PM
David Buschur
187
Mar 23, 2008 05:06 PM
