Any Evo Holset setups on here?
Old Nov 12, 2009 | 07:17 PM
  #31
colonelfox's Avatar
Originally Posted by 3gEclipseTurbo
I have a 2.4l 4g64 thats why i was looking to go bigger than the average dsm. i figure ill spool a hx50/hx52 to full boost around 3500-4000rpm. Sound about right? ANd where can i even get these ive tryed searching for them for the last 2 hours all i get is forums, if theres no online stores what truck does a hx50 or hx52 come off of?
Probably not. Keep in mind, you're only .4L larger displacement which will give you something like a 300-600 RPM decrease in spoolup. I noticed very little difference going from a 2.0 to a 2.3L running the SC61. Just a few hundred RPM which is almost imperceivable. If you were running a 3L it might be a different story. Trust me, stick with an HX40 or 35. They both can make the power you're looking for on pump without being pushed to the limit. The 52 would not be a good daily driver turbo IMO. Lag sucks. It gets hair raising if you have to pull out into traffic at WOT and wait, and wait some more until the car hits 6K RPM and you actually start accelerating at a reasonable pace.
Old Nov 12, 2009 | 07:42 PM
  #32
3gEclipseTurbo's Avatar
I thought th .4 would give me more like 1k sooner spool, my buddy has a dsm we both have the same turbo where i start spooling like 1900 and he starts around 2900 idk. I guess ill go with the hx 40 but still where can i get one? Ill start calling junkyards tomarro. What does the hx 40 come off of?
Old Nov 12, 2009 | 09:00 PM
  #33
jouniu's Avatar
As said earlier, dont buy basic hx40 single scroll, try to find out twin scroll hx40super,
Old Nov 12, 2009 | 09:17 PM
  #34
Where do they sell holset turbos??? Ive just wasted another hour of my life try to find someone that sells them.
Old Nov 13, 2009 | 05:26 AM
  #35
[I.R.A.]_FBi's Avatar
start with ebay or cummins diesel forums
Old Nov 13, 2009 | 02:38 PM
  #36
colonelfox's Avatar
I found mine on ebay. There's several for sale now.
Old Nov 14, 2009 | 11:55 AM
  #37
sparky's Avatar
You will not be able to spool a straight HX-50, or HX-55 with a 2 Liter enigine. I ran a hybrid J.R. Adkins HX-50 on my Dodge Ram Cummins turbodiesel which is a 5.9 Liter engine.
The Adkins hybid mates a 50 comp wheel to an HX-40 turbine wheel allowing the use of an HX-40 DP. It is a quicker spooling turbo than a straight HX-50. But, even so, to get it to spool by 4000 RPM I had to throw Meth at it starting at 3200 RPM, otherwise it didn´t wanna spool before 4500 on straight diesel, and that was with the smaller HX-40 hotside and using Meth as a spool enhancer at low RPM´s and on an engine three times the size of an Evo. We did see 50# on top though.
Good Luck though
Old Nov 14, 2009 | 01:14 PM
  #38
wht420aeclipse's Avatar
I thought I'd post this up for those who are looking at using a Holset, all this info is from DSMtuners and it is actual seen and recorded #'s not guesses.
Summary provided by wiseman, Dsm-onster:
HX35:
The 8blade hx35 has a 56mm compressor inducer. This is found on 1995-1998 cummins manual pickups. The compressor flows 52 lb/min according to the compressor map. The bolton BEP housing (0.55 a/r) is enough to push the limit of the compressor. There's several 500whp 8blade hx35 cars out there with the bolt on housing. It reaches 20+psi by 3500rpms in 3rd with 272 cams. Smaller cams would equal a faster spool speed in most cases.
The 7blade hx35 has a 56mm compressor inducer. This is found on the 1999-2002 cummins manual pickups. The compressor flows 60lb/min according to the compressor map and logged results from a member here. The bolton BEP housing with the hx35 turbine wheel do not SEAM to have enough flow to really reach the potential of 60lb/min. But many have logged over 50lb/min so far and seen 500whp. The stock hx35 12cm^2 twinscroll turbine housing is a t3 flange housing. This mated to a NON-divided runner manifold has produced a 132mph trap speed with a full weight 1g AWD. This is about 600whp. So the flow is there with the stock housing if you use a non-divided manifold. The spool speed of the 7blade hx35 is similar to the 8blade hx35 with 20+ psi by 3500rpms in the bolton housing and by 4000rpms with the stock housing with a non-divided manifold.
HY35:
The hy35 has a smaller turbine wheel than the hx35. And, it has a turbine housing connection that does not allow for a bolton housing to be used. It does not have a divided housing so any t3 manifold can be used effectively with this turbo. It has the same compressor as the 7blade hx35. We don't know if te hy35 turbine wheel and housing is enough to reache the 60lb/min potential of the 56mm 7blade compressor. Some one try it out already!!! It should at least be a faster spooling viable option to the full t3/t4 50-trim.
H1C/WH1C:
In 1994, there was the Wh1c which has pretty much the identical compressor as the hx35 but with a Vband compressor cover. The turbine wheel is the same. It will bolt into the BEP bolton hx35 turbine housing. It has 4 bolts at the housing instead of 6. So you will need to buy 2 more bolts and use 6 washers cut to make a flat side. Honestly, I just used bolts that were cut a little short and the bolt head was wide enough to pull the chra to the turbine housing. No sealing issues. Since the Wh1c is for all practical purposes an 8blade hx35 the spool and flow is the same too.
I have the big h1c. It comes on the INTERCOOLED 1991-1993 cummins pickups. It has the webbing for MWE but no groove cut like the hx35/wh1c has. This turbo I term the big h1c because it has a 54mm compressor inducer and same exducer than the 8blade hx35/Wh1c. The other h1c is the small h1c found on the NON-intercooled cummins pickups. This has a 50mm inducer but only 7blades and has no webbing for MWE. Less blades helps flow, but so does a larger inducer diameter. The most whp ever recorded on a gas 4cylinder with the small h1c was done on a KA24 nissan: 411whp. Since the big h1c has a 4mm larger inducer and the same turbine wheel as the hx35, it is safe to say that it flows enough for between 411whp and 500whp. The diesel sources state that it flows SLIGHTLY less than the early hx35. So 4lb/min less than the 8blade hx35 puts the flow of the big h1c at 48-49lb/min right where a 50-trim or 20g is. The small bep housing is all that's needed to get the most from the compressor and the spool speed is 20+psi by 3500rpms.
HX35-40 hybrid:
Keeping the long tradition of the marriage of sportcompact and hybrid turbos, there is the hx35 turbine and the hx40 compressor. It is strongly recommended to use the large bep turbine housing or the stock hx35 turbine housing with an non-divided t3 manifold for this turbo. The small bep housing around a t31 size hx35 turbine wheel is probably not enough to merit any of the hx40 compressor wheel upgrades. 20+ psi by 4000rpms can be seen in the hx35/40 with the hx35 12cm^2 turbine housing with a non-divided t3 manifold. With the large bep housing, spool times are to be determined. But likely similar.
HX40:
The 8blade hx40 has a 58mm inducer and flows about the same as a 60-1 (around 60lb/min) with ALOT better high boost efficiency and spool speed. It is the most common hx40 out there. The small bep housing with the hx40 turbine wheel is plenty to reach the full potential of the 60lb/min 8blade hx40 compressor. 20+ psi by 4100rpms with 272s.
The 7 and 6 blade hx40 is called the super40 and has the 60mm compressor inducer. This compressor flows around 69lb/min. You can get this wheel in billet style (think HTA). The non-billet wheel spools as fast as the 8blade hx40 in the bolton bep housing and has done 653whp at 40psi per the holset results only thread. Billet should spool even faster. The t3 .70 a/r BEP housing slows spool about 400rpms. But reports show a significant gain in flow per psi. So expect more power at lower boost with that turbine housing.
H1E/WH1E:
The Wh1e is like it's little brother the Wh1c. It mirrors the hx40 8blade in every way except that it has a v-band compressor cover and a 4bolt chra-turbinehousing pattern. It will consequently bolt into the hx40 bep bolton turbine housing and this is plenty of flow to max out its 60lb/min compressor.
The h1e is like it's little brother the h1c. There are different size compressors. . . BUT there are also different size turbine wheels too. Check measurements before buying this turbo if you plan on running a BEP turbine housing. There are lower flowing compressors than the 58mm 8blade that are out there. So this turbo may not flow any more than an hx35 if get the wrong one. You need at least a 58mm compressor inducer for this to be a worthwhile turbo vs the proven hx35 or 8blade hx40.
HX52:
This is a big sucker. It is commonly found on the Volvo Semis and usually has a billet compressor wheel. It flows 88lb/min. There is no bolt on housing for it. If you want a bolton housing for this turbo, then you don't want this turbo. In fact if you want a t3 flange turbine housing for this turbo, then you don't want this turbo. You DO want this turbo if you're looking at a gt4294r or gt4202r. The turbine inlet is slightly different than a t4 bolt pattern. You can still get the t4 manifold to work just fine by enlarging the bolt holes.
Misc.:
Holset's don't spool slow. They spool faster than their garrett or mitsubishi counterparts. Diesel exhaust is cold and slow moving.
The holset turbine wheel is a work of art. It has been shown to flow very well in a very small turbine housing. For example the hx40 turbine wheel in the small .55 ar bep bolton housing flows as much as a garrett gt35r turbine wheel in a larger .63 ar garrett t3 turbine housing. The hx40 with this configuration spools about 500rpms faster! You can upgrade to the .70 a/r BEP t3 turbine housing and have the same or slightly faster spool speed as the above gt35r with ALOT more flow per psi and consequently more horsepower per psi. This makes for VERY good pumpgas numbers.
Holset patented map width enhancement. They do not have extended tip technology, but there compressors show more efficiency than their garrett or mitsubishi counterpart.
They have superback technology witch leads to VERY, VERY durable compressors. The are designed to be overworked and underpaid.
There are discrepancies all over the web concerning the compressor maps. Take what you hear/read with a grain of salt and a shot of tequila, and the worm.
The holset is fine with stock 4g63 oil pressure from the oil filter housing. If you have no b shafts, you'll need a restrictor. The drain line is a garret bolt pattern. The feed line is different for different turbos.
Old Nov 14, 2009 | 01:20 PM
  #39
Oh forgot to mention I run a HX35 with the BEP .55a/r on my stock 2.0l. I see 30psi just a hair past 3500rpm, it's a waste of time running anything lower than 20psi on this turbo it really feels like someone flips a switch when it starts to spool. I'm on E85 with 20deg timing and have traction problems in first and second.
One more thing with these, oil pressure issuses have been killing these turbos and giving them a bad name. No more than 60psi and a minimum of a -10an drain.
Old Nov 14, 2009 | 02:11 PM
  #40
RevMoto's Avatar
Would love to see your engine bay and a dyno graph
Old Nov 16, 2009 | 03:59 PM
  #41
colonelfox's Avatar
Looks like I was wrong. I spent the weekend replacing the flange I made with a new one so I could get the downpipe angle a little better (didn't seal and leaked a bit). It looks like the weld on the stock turbine wastegate port had failed and I was leaking exhaust through it. I sealed it up and put it all back together. Now I'm running obscenely lean at WOT 14.7 and hitting 29 PSI at 3900 RPM. Considerably different power band than what I experienced before but I have to completely retune the A/F map all over again. Unfortunately I was planning to dyno it Saturday and I might not have enough time so it may not happen.
Old Nov 16, 2009 | 05:15 PM
  #42
fox ygpm
Old Nov 19, 2009 | 05:29 AM
  #43
SyZyGy1394's Avatar
Fox, got some pics of your setup?
Old Nov 19, 2009 | 06:05 AM
  #44
Justin VIII's Avatar
extremely interested in this topic, have acouple of friends with dsm's that run holsets. they are currently talking to Bullseye ( for me) to see if they can fab up an Evo mani for the Holset turbos, so we can actualy use these holsets without much problem. more to come
Old Nov 19, 2009 | 06:13 PM
  #45
bambooi's Avatar
May we get PICS of your setup COLONELFOX?
