aluminum rods
Old Dec 3, 2008 | 12:11 PM
06rs_power's Avatar
aluminum rods
Ok here is what i figured out tonight.
These weights are for a full set of rods of a leading brand
steel= 3320 grams = 7.31934662045 pounds
aluminum= 1820 grams = 4.01241241290639 pounds
witch is a difference of 3.30693371406 pounds
In the book Chassis engineering by Herb Adams they had a figure that showed that taking out 15 pounds of rotational weight is good for 32.1 horse
witch is 2.14 horse per pound
witch would mean that a set of aluminum rods should make 7.0768381480884 horse more then a set of steel rods.
Besides this fact and the fact that the aluminum rods are better for the life of the bearings why would I want to run them in a motor that is expecting 650 horse and up to 40 pounds of boost?
Price seems to be a little cheaper for the aluminum rods if you only look at the higher quality steel rods.
Old Dec 3, 2008 | 12:16 PM
jmtx86's Avatar
Well Al. rod absorb a lot of shock that would otherwise be transfered to the bearing, however Al. + a lot of heat and then start to get weak. I would like to Al. rod in my car but id like to see how long they are lasting for people using them.
Old Dec 3, 2008 | 12:53 PM
ScorpionT's Avatar
It all depends on where the rotating/reciprocating mass is.
I would still prefer steel rods, because they hold up under extreme tension better than aluminum rods.
Old Dec 3, 2008 | 01:44 PM
hopper's Avatar
its the heat cycles that kill aluminum rods. not the shock. Personally I would feel comfortable building an all motor vehicle with aluminum rods. but not for a turbo application thats not a drag car. additionaly if you do decite to go this route. make sure when you build it that aluminum expands to heat differently than iron/steel. So take that into consideration because This usually ends up with a "noisy" motor untill its warmed up. and make sure your clearances will be correct.
Old Dec 3, 2008 | 03:25 PM
justboosted02's Avatar
significant figures.... use them
Old Dec 3, 2008 | 05:03 PM
Billy@EnglishRacing's Avatar
I think that price, weight, and increased bearing life should be enough of a reason to go with a set of aluminum rods over a set of steel. If you only plan on using the motor for 30k i don't see the rods giving up before the 30k are up.
Old Dec 3, 2008 | 08:51 PM
JohnBradley's Avatar
While the tensile differences make steel more favorable, the harmonics induced because of the steel pounds bearings above 600whp far faster than aluminum.
I agree with you but practicality dictates something else at that power level I would think. Ti is an option but cost prohibitive for most.
Old Dec 3, 2008 | 10:07 PM
wshihdnevo's Avatar
Ti would be the way to go, but very very expensive if you have to change them out before their expected life span.
RS200
Jan 28, 2016 06:12 PM
EVOlutionary
35
Aug 1, 2012 02:48 PM
Billy@EnglishRacing
Dec 3, 2008 07:53 PM
AutoMotoSports
Sep 25, 2008 08:32 PM
David Buschur
18
Mar 5, 2008 09:02 AM
