Transmission Cooler
Old Dec 16, 2008 | 01:48 PM
4G63K's Avatar
Transmission Cooler
Has any one used a tranny cooler?? It seems like it would hel the MR guys stay cool on the track.. any input??
Here is a link.. maybe there us something more specific for the Evo
http://www.modacar.com/products/Mits...sal+Trans.html
I know it says automatic... but why wouldnt it work for a manual?
Old Dec 17, 2008 | 08:47 AM
4G63K's Avatar
Bump...???
Old Dec 17, 2008 | 09:08 AM
Q15H's Avatar
The X MR has a gearbox oil cooler from the factory - it's in the left side between the left side foglamp opening and the inner fender shield (with air exit holes in the shield). It probably just needs more airflow, maybe a fan so it'll cool when stopped. Removing the foglamp (and maybe the LICP??) and a little ducting will get much more airflow across the cooler core. A fan could also be added but that would only help at low vehicle speeds.
If I ever get that problem - the SST gearbox overheating - I'd rather install a different [coolant] radiator with an auto gearbox fluid cooling loop. Much more cooling capacity that what an air cooler cna provide. Maybe next summer.
Old Dec 17, 2008 | 09:14 AM
JdmEvo's's Avatar
I did a short research on this when I was deciding between a MR and a 5-speed. But the only thing I see missing from that kit is a pump.
Old Dec 17, 2008 | 09:35 AM
Indy Evo's Avatar
A Mocal 10 row x 3" high with a 11 3/8 or 6 5/8 wide core should get the job done depending on what kind of road racing is involved short or long track configuration. An electric Mocal pump with either -6 or -8 lines and a stainless mesh screen filter should round out the package. Proper support of the cooler and a rock screen is necessary to prevent cooler breakage. In the event you can not locate Mocal products Earls Indy or C&R Racing in Indianapolis can help you out with cooler, lines, pump, and fittings for your specific application. I hope this helps. Indy
Old Dec 18, 2008 | 10:30 AM
4G63K's Avatar
Thanks guys.. has anyone done this befoer on an 8 or a 9?
Old Dec 19, 2008 | 08:14 AM
hokiruu's Avatar
Look up member KidLoco (I think there's a number like 61 or something after his name)
he made a very nice, very clean, and effective tranny cooler for his 6-speed.
Old Dec 20, 2008 | 01:47 PM
Laxman's Avatar
https://www.evolutionm.net/forums/ev...on-cooler.html
Try this thread
Old Dec 20, 2008 | 01:55 PM
Evolution IVGSR's Avatar
My Evo IV came with a Oil cooler, Trans cooler, and a rear diff cooler Gota love JDM Cars
STM Tuned
May 5, 2019 12:51 PM
bnr34rb26dett
53
May 6, 2012 06:30 PM
BLUE EVO702
23
Sep 16, 2010 10:41 AM
pcasupreme
Mitsubishi TC-SST Discussion
11
Jul 14, 2009 08:20 PM
ghoonk
40
Jul 2, 2007 07:37 AM
