HKS Camp System
HKS Camp System
I just saw this, I know very little about it. Is it JUST a data logger/screen set up with sensors, or does it control anything? If its just a data display with alarms and such, it's cool, but I figure the Greddy E-Manage will do with the addition of the Profec-E01 and a standar boost/egt/fuel pressure set up. Unless there is some added benefit to putting this on AS the gauge set up on the vehicle. Any ideas? BTW, Im going with the full Greddy E-Manage with the profec and all the associated wiring.
HKS Camp system does not control anything. It collects data from sensors such as boost, temp, pressure, rpm, speed. The data is output to your choice of LCD screen. It's a digital gauge. It's really cool, but expensive setup.
I might miss out some extra feature. But it will not control air/fuel or timing like emanage and boost control like profec.
A dealer at this forum has one forsale. Check it out.
https://www.evolutionm.net/forums/sh...light=hks+camp
Is it just the controller box? For a complete Camp setup, there is many other wiring harness, sensors and the juction box.
Without the juction box, you will not get other sensor reading.
You will only get RPM, speedo...
In additional to this, you will need a LCD screen. No LCD, no display.
Originally posted by 1QWKEVO
I've got one 215 shipped anywhere, new in box... don't have a screen yet to install it
Exactly - there is the cpu, junction box, and the sensors, and finally the LD screen.
Installation is not hard at all - very straightforward in fact, though it helps if you ahve wired gauges in before.
EVOsound
Apr 13, 2005 01:32 PM
HobieKopek
Lancer Engine Tech
47
Apr 7, 2004 01:06 PM
