Ted B.'s HTA3582 Twinscroll Project
Old Jan 15, 2009 | 10:20 AM
  #91
Geoff Raicer's Avatar
Originally Posted by Ted B
I've had a 35R with open .63 A/R before, but it wasn't anything like this. There are no dead spots. It picks up from an idle in 1st gear and just feels like the car is rolling downhill all the way. I'm hitting 20psi almost 1000rpm quicker than I did with the open T3 35R, and the big 1.06 A/R TS T4 flows well enough to see the limits of anything this turbo can deliver on any fuel....Originally I had the HTA3582 reserved for my BMW
Initially I was skeptical, but it turns out that this is the quickest, quietest, most foolproof BOV on the market. It works so well, I forget it's there. I only know it's working because there is not a trace of flutter. If you want a toy that chirps and burps, get something else. If you want performance without leakage, get this.
thats really great to hear your positive results. peter medina is a real nice guy, im stoked your turbokit is working so well for you.
what BMW are you building? that is exciting i want to see pics i have a soft spot for M52 engines...
Originally Posted by Mark S
I have run a GT4088 twin scroll at 2.6bar boost and 4bar base fuel pressure and still 95% injector duty on RC 1000cc injectors and still had more pump left,
As the 044 pressure rises it will reduce its capacity but as this happens the walbro increases its back pressure to it so again adds a bit more pump out of the 044.
hi mark -- ive got 3 fuel system questions for you
1) have you tried the bosch 040 intank pump? its a 300lph unit
2) have you tried running a bosch 044 inline, but installing it intank? Basically putting it on the pump hangar, and routing the walbro through it, but keeping in the tank. ive never seen this, just curious
3) have you tried the bosch 1000cc injectors? ive heard fantastic things about their spray pattern at high rail pressure.
The only Aeromotive product I use is the Eliminator Fuel pump, I do not like there Regs as most I have had in have problems.
thats interesting, i run the eliminator on a cpl cars but its just so absurdly loud i really prefer to use dual bosch's anymore. Their A1000 is a total POS fuel pump, hated it and went thru 3 of them at great expense to me.
what problems did you have with their regs? ive had good results.
Originally Posted by justboosted02
why not go with a wrap? i had my subaru up-pipe swain coated and it only lasted 6-8 months before it started chipping
i believe in coatings + wrappings. less heat out is better. Did swaintech warranty the coating??
like scorke said some of the gains are likely due to the cooler water temps and IATs.
Old Jan 15, 2009 | 10:24 AM
  #92
riceball777's Avatar
great results.
I can't wait to get my fill rave twin scroll kit on
Old Jan 15, 2009 | 11:36 AM
  #93
Ted B's Avatar
The E30 M3 uses the S14 engine, which powered the car to more rally championships than any other sedan. Mine is 2.5L, and fully built (beginning work on the shortblock now). I'll post pics when the car is complete.
As for an update on my EVO, we've found the cam gear teeth to be excessively worn, so those are being changed along with the idler assembly, etc. I should be able to conclude my tuning following that.
Old Jan 15, 2009 | 11:39 AM
  #94
j14mp's Avatar
looks amazing! is the motor really that solidly in place that it can have a hard pipe for a radiator hose? or does the fitting flex enough.
Old Jan 15, 2009 | 12:03 PM
  #95
Mark S's Avatar
Geoff
I have not seen or heard of a 040 only a 044, I will look in to a 040 as that looks like a good flowing pump,
The way I do my fuel systems is a wablro in tank running staight in to a 044 external, The walbro runs 1 bar of back pressure in to the 044 which increases the 044 output, At 4bar base fuel pressure it will supply enough fuel for a GT4088 running 2.5bar boost with a small amount of head room,
Do you have the full part number of the bosch injectors as I have not seen them,
I also tried a sard 280lt fuel pump this did not supply any more fuel than a walbro unless it was run at low fuel pressure i.e under 3bar base,
The Evo 8 onwards has a problem fitting a bigger size than stock fuel pump unless you cut the housing so I have not tried anything other than a twin wabro in tank and in my testing that only flowed 15% more than a single walbro,
Every car I have had in with a Aeromotive feul reg have had problems holding fuel pressure on boost and a quick change to a sard or a Kinsler reg fixed the problem.
Mark
Old Jan 15, 2009 | 12:20 PM
  #96
401tuner's Avatar
veryy nice!
Old Jan 15, 2009 | 12:41 PM
  #97
Ted B's Avatar
The motor has a delrin front mount, and cannot present enough movement to stress the couplers.
Old Jan 21, 2009 | 07:20 PM
  #98
juanmedina's Avatar
Wasn't the HTA wheel and TS supposed to be a mismatch?
I am looking for TS turbo T4 with vband for my Suby any suggestion? I am looking for fast spool
Old Jan 21, 2009 | 07:37 PM
  #99
Ted B's Avatar
The advantages of TS are apparently dependent upon turbine efficiency, and I believe his concern was that increasing compressor efficiency alone may create an imbalance in favor of the compressor. In actuality, the HTA + TS seems to really (and I mean really) work well.
I don't know what you define 'fast spool', but if you have the means to support the power potential of an HTA3582R, the TS T4 setup seems to work exceptionally well.
Old Jan 21, 2009 | 08:06 PM
  #100
CBRD's Avatar
ted, youve got pm
cb
Old Jan 21, 2009 | 08:08 PM
  #101
evoracingstar's Avatar
looks real good!!
Old Jan 22, 2009 | 05:09 AM
  #102
juanmedina's Avatar
Hey Ted B who supply you with TS HTA 3582R? How about 3586R?
Thanks
Old Jan 22, 2009 | 06:30 AM
  #103
Ted B's Avatar
You can get them from Forced Performance, AWDMotorsports, or Buschur racing. I wanted the 3582R because I don't need >700whp, and I want the quickest possible spool.
A note on my progress:
I am out of fuel with E85, 12:1 AFR, at 30psi and an indicated 3200+ Hz airflow with the FIC 1250s. Time for FIC 1450s . . .
Old Jan 22, 2009 | 06:58 AM
  #104
supersal's Avatar
Ted how would this HTA82 compare with:
GT35R with a T3 1.06 Twinscroll hotside
vs
T04Z with a twinscroll T4 .84 hotside
vs
GT4088R with a .95 Twinscroll hotside
I am considering one of these plus a Autronic + 1000cc Injectors as my next upgrade...
I want max power with min lag yet torquey and drivable streetcar.
Thanks
Sal
Old Jan 22, 2009 | 11:52 AM
  #105
ncaruso23's Avatar
Super clean, really nice.
