Ted B.'s HTA3582 Twinscroll Project
Old Feb 8, 2011 | 03:27 PM
  #211
Ted B's Avatar
I replaced a blown turbo gasket, and in doing so, refitted the flange with sufficient hardware such that the flange bolts cannot back out.
While I was at it, I fitted a Tomei windage tray and crank scraper. Be advised the scraper feature is useless without user intervention.
Doing some tweaking, I discovered that I can roll right past MBT at high rpm without knock, despite throwing almost 40psi at it with 93 octane. I've made an adjustment to the cam timing to remove a bit of overlap, and I'm going to have to do some careful road tuning to finalize the 93 octane mapping before I swap over to E85.
Old Feb 8, 2011 | 03:40 PM
  #212
R/TErnie's Avatar
what hardware did you use?
Old Feb 8, 2011 | 03:46 PM
  #213
RSMike's Avatar
If you can reach MBT with 93octance, will you get horsepower gains with E85? i thought that was the whole point of E85, more timing.
I love how effective that water injection is
  #214
Ted B's Avatar
I used:
- High grade socket screws in 35 or 40mm length (can't recall)
- SS serrated face Belleville Washers (McMaster)
- Copper exhaust manifold nuts
Old Feb 8, 2011 | 03:50 PM
  #215
Ted B's Avatar
This is without the water injection activated. With WI, even an occasional midrange 1-count goes to zero. My plan is to tune to the edge without it, then activate it as a buffer.
If MBT can be reached on 93, there doesn't seem much point in going to E85 except as a more forgiving fuel. Anyway, it appears as though this is the case, but I need more tuning time to be certain.
Old Feb 8, 2011 | 04:21 PM
  #216
RSMike's Avatar
arg i still wanna know how you've done it! seems like magic
With E85 my tuner found that a GT3582R T3 TS on a SR20 spooled up 300rpm faster too. I wonder if that will be the case with your setup?
Old Feb 8, 2011 | 04:54 PM
  #217
miragevo's Avatar
Veteran: Navy
Can you go into detail on the install, as I have the Tomei unit and plan on installing it on my stock 2.0L this spring.
Old Feb 8, 2011 | 05:22 PM
  #218
Ted B's Avatar
Same here, ~250rpm.
I'll do a writeup - have photos. Basically, you will need to bend each scraper tab until it virtuallly touches the crank counterweight at the point of minimum clearance. You'll need to get under the car and rotate the crank by hand to get each tab set in the best possible position. If you don't do this, the scraper will be useless.
Old Feb 8, 2011 | 05:25 PM
  #219
miragevo's Avatar
Veteran: Navy
Thanks, I'll be looking for the write-up.
Ted B
Aug 4, 2016 08:46 PM
Ted B
Jul 26, 2014 07:08 AM
Ted B
58
Jun 21, 2012 01:29 PM
Ted B
Jan 12, 2011 12:44 AM
Ted B
Feb 17, 2010 08:52 PM
