Ted B.'s HTA3582 Twinscroll Project
Old Dec 21, 2009 | 06:50 AM
  #181
cij911's Avatar
Congrats Ted....What is you power band like (5500 - 8500 rpm) ?
Old Feb 16, 2010 | 07:37 AM
  #182
mega-z's Avatar
This car will make a dead man scream!
Old Feb 16, 2010 | 08:14 AM
  #183
Ted B's Avatar
It's running pretty well, but there's more in it. I'm making a few adjustments and going back to log the difference.
Old Feb 16, 2010 | 08:38 AM
  #184
R/TErnie's Avatar
get us some datalogs Ted! A video would be nice too!
Old Feb 16, 2010 | 08:50 AM
  #185
Ted B's Avatar
I will post a writeup with a log and VDR graph as soon as I finish tweaking the 93 octane tuning. As of now, it's hovering at 560-570whp with goose eggs in the knock sum column, and there's more left in it. Needless to say, it spools and drives wonderfully.
Old Feb 16, 2010 | 08:57 AM
  #186
R/TErnie's Avatar
what Rc is your Engine Ted?
Are you using a steel rod or aluminum rod?
Old Feb 16, 2010 | 09:08 AM
  #187
fre's Avatar
fre
I believe he is using Oliver steel rods and Venolia ceramic coated pistons. I am looking into the same setup for my build. Pretty impressive hitting 560whp on crappy pump gas. I am lucky to get 400 out of mine on pump. Good thing we have E85.
Old Feb 16, 2010 | 09:11 AM
  #188
mega-z's Avatar
TwinScroll FTW!!!
Old Feb 16, 2010 | 09:14 AM
  #189
Ted B's Avatar
The rods are Oliver billet 156mm.
Rc? Hmmm, not finding a definition for that in my mind.
Old Feb 16, 2010 | 09:21 AM
  #190
Drifto's Avatar
Maybe he meant CR?...
Old Feb 16, 2010 | 09:38 AM
  #191
R/TErnie's Avatar
Compression Ratio is technically abreviated as Rc according to Mr. Heywood.
Old Feb 16, 2010 | 09:42 AM
  #192
Ted B's Avatar
Ah, I consider that to be SCr - static compression ratio. In my case, it's a measured 8.9-9.0:1.
Old Feb 16, 2010 | 10:22 AM
  #193
R/TErnie's Avatar
Brings me to an interesting question.
Dynamic Compression being held the same... if you change your static compression ratio how does that effect the performance of the engine? What are the tradeoffs per say?
I'm sure you designed your cams to give you the DCr that you wanted. Thanks in advance.
-eric
Old Feb 16, 2010 | 12:58 PM
  #194
Philthy748's Avatar
Just finished reading this thread, great job Ted and you are a very patient person...! Looking forward to seeing your dyno results...
Old Feb 16, 2010 | 01:22 PM
  #195
dude's Avatar
Don't let Ted fool you...he has e85 right down the road from his house.
Ted, you need to make the switch to Big Maps and e85. I just need to get the maptracer excel sheet to work with bigmaps and older versions of MS office.
