Evo 9 MR fuel problem
Old Dec 21, 2008 | 10:54 PM
djmixerx's Avatar
Im posting this for my bro. He really not a car guy but wanted power so he installed a bunch of aftermarket parts to make his car faster. Turbo, IC Inj, pump, fuel rail, some coil thing. etc... Now he having problems with his fuel management I assume. He brought his car to some evo specialist and they couldnt find the problem. He was describing to me that its way to rich at idle and gets way lean while driving. He has some type of engine management which I forgot and switched it out to the stock one. It still has the problem. Tried switching out the injectors to see if those r bad not the problem. Also changed 02, switch coil packs. Almost everything but still have find the problem. Any suggestions. I know this is vague but thats all I can remember with his setup.
For the last time I drove it, it sputtered in the beginning and would be able to drive after 3k rpm. Im not Evo guy I drive a DSM so it kinda felt like the duty cycle was off. But they said it was setup for his injectors. I have no idea wat it could be maybe its a EVO problem.
Old Dec 22, 2008 | 12:06 AM
chaotichoax's Avatar
huge boost leak...intercooler pipe is undone possibly
boost leak test is a good start
Old Dec 22, 2008 | 07:36 PM
djmixerx's Avatar
I believe they checked that.. A shop and his friend. Any other suggestion?
Old Dec 22, 2008 | 08:45 PM
HyaboostaIX's Avatar
my IX MR would barely even drive with a massive boost leak. Make sure your plugs are all ok and the coil packs are functioning correctly. Also make sure the tune is correct.
Old Dec 22, 2008 | 10:45 PM
djmixerx's Avatar
He keeps blackening his spark plugs.
Old Dec 22, 2008 | 10:54 PM
bluebanana23's Avatar
excess fuel...did he get a retune?
Old Dec 22, 2008 | 11:17 PM
djmixerx's Avatar
I believe so.
Old Dec 22, 2008 | 11:23 PM
djmixerx's Avatar
I believe so. Thats y he when to the shop but they couldnt figure out what was the problem.
Old Dec 23, 2008 | 06:28 AM
JakeTheVIII's Avatar
If you take them an evo with those basic mods, and they cannot discover the problem, they are not an evo specialty shop.
It should not be this hard to find the problem. Do a boost leak test. If that checks out, it's probably fuel related. Check pump, injectors, or whatever you havent checked. If you cannot narrow it down, take it to a real reputable evo shop close to you. The spark plugs are probably indicative of your problem.
Old Dec 23, 2008 | 06:34 AM
sparky's Avatar
Which shop have you taken the car to?
egis
Sep 18, 2015 07:37 AM
SilverEvoX
North Texas Evo Club (NTEC)
12
Aug 13, 2012 11:20 AM
evo9nuuub
13
Sep 16, 2010 01:01 PM
GraphiteEVOIX
13
Aug 28, 2007 11:49 AM
Noize
29
May 20, 2005 12:00 AM
