need help chosing parts. evo 9 only get one cam gear?
wow mellon, hearing your setup is making me happy and excited! and im beginging to think i am actually going to see low 10's with this setup.
what do you think about this? junk?
http://cgi.ebay.com/ebaymotors/ws/eB...id=p2759.l1259
mellons setup making me excited and actually beginging to belive in my car and build again, i almost lost all motivation and hope. one more thing..
exactly what im thinking!. you guys and your help is amazing, when its a little warmer im going to throw a evom party at my house, lots of booze beef and women, for everyone who wants to come to pa from here.
Some people say that spark tech is a really good ignition that is the one that i was planning on buying.
I like the kelford cams and if you are going with a big turbo then get the 272 cams.
I hope that we have all helped you with the decisions on your car.
i think im gonna go with the hks 272's and retain the stock gears, you guys are terrific, i got every single answer i need except 1. well maybe two haha.
the little black sensor thats clipped onto the braket that holds the intake manifold on, its under the manifold clipped onto the braket, it has a wire plug and 3 vacumm ports, what is it and do i really need it? previous owner had the egr taken off and they left this thing plugged in and just left the 3 vacumm ports open, im only assuming this was part or the egr removal, can i just unplug this thing and take it off my manifold braket? or do i have to hook vacumm lines back up to it, or cap the lines and leave it plugged in?.
and number two: simple. is there anwhere i can find a diagram on where these "thrust washers" go exactly, like a drawing or picture or something like that. and is there like book/manual i can buy for this car? like a really good one with every spec. and info i need on putting this car and engine back together?
one more. then im done. i promise.
where the transfer case bolts to the transmission it lookes like theres some kind of a oil hole or something where the 2 faces meet. it looks like it should have some kind of a washer/ gasket, is this true. its seems that if theres no little washer it will leak when i bolt them together and fill em up or am i just imagining things and should just bolt the 2 together?
no more questions............. for now...ha. you guys are amazing
You can find the workshop manuals on ebay (where I got mine) pretty cheap, like $20 and under, it's all on one cd. All of your specs and pics will be there.
The hole you are talking about should be the oil transfer hole, yes a small o-ring does go there.
I don't know about the sensor you are talking about, I'm going to be working on my car tonight so I'll check out where that stuff goes if someone elso doesn't post up first.
ChanceR
10
Aug 12, 2011 10:04 PM
jba3
Feb 6, 2008 06:04 PM
