Air bypass Vacuum to Wastegate Acuator, Help! (pics)
Old Jan 15, 2009 | 03:26 AM
H8my8's Avatar
so these are the instructions for reloacting the vacuum hoses when installing the turbo outlet pipe and lower intercooler pipe, I'm having some trouble understanding them if anyone can help me Thanks in advance.
Originally Posted by greddy
Vaccum Line Installation
Use the provided 5
 rubber hose and three-way joint
to connect the air by-pass vacuum line to the
waste-gate actuator vacuum hose three-way joint
(A).
Parts used: <��, ����, ����>
Old Jan 15, 2009 | 07:15 AM
PVD04's Avatar
Take the vacuum line that connects to the turbo outlet pipe and tee it into the line going to the by-pass valve. Don't disconnect anything else.
Old Jan 15, 2009 | 02:33 PM
EvoDom's Avatar
why are you even doing this??? i never even saw this and i have an 02 hosing and all intercooler pipes. ive never seen this before dont even bother.
Old Jan 16, 2009 | 03:37 PM
edardnaekim's Avatar
??? He is doing this because the licp he has doesnt have a nipple on it like the stock one does...
Old Jan 16, 2009 | 06:42 PM
TwoFour's Avatar
ouch! where'd you get it from?
Old Jan 16, 2009 | 07:47 PM
H8my8's Avatar
I am still running the stock LICP, the LICP I'm tryin to install is from the Greddy Intercooler kit I bought.
Old Jan 16, 2009 | 08:11 PM
randomevo's Avatar
because the intake doesn't have a nipple not the licp right?
Old Jan 16, 2009 | 10:33 PM
no, is licp is two peices, it comes with its own turbo outlet pipe. the stock turbo outlet pipe has a nipple on it for a line, but the greddy licp kit he has eliminates the stock outlet pipe, and the one in the kit does not have a nipple on it.
Old Jan 16, 2009 | 10:39 PM
EvoJoeIX's Avatar
is this something only on 8's?
my licp has no vac lines going to it at all
Old Jan 16, 2009 | 10:55 PM
your pipe that comes right off the turbo does, but his kit comes with a replacement for it which doesnt unlike oem. most licp's sold dont replace the stock outlet pipe, but greddys and i think the br deluxe does.
Old Jan 16, 2009 | 10:56 PM
to op, have you tried what PVD04 suggested?
Old Jan 16, 2009 | 11:15 PM
EvoJoeIX's Avatar
oh okay, your talking about that peice that bolts onto the end of the turbo that connects to the licp
Old Jan 17, 2009 | 02:40 AM
H8my8's Avatar
Exactly, I understand the situation however I'm still confused when I look under the hood I can't really locate the line I need to put the T hose connector in and run the vacuum from j pipe.. anyone have tips on locating the correct line? Under the hood it's alot more complicated then their pictures.
Old Jan 19, 2009 | 03:20 PM
From what PVD04 is saying, he wants you to tee into the dv line, if you have stock intake, the dv is on top of the intake tube.
Old Jan 19, 2009 | 06:17 PM
PVD04's Avatar
The vacuum line you want comes from the intake manifold and runs through some hard lines on top of the valve cover. You can tee into the vacuum line anywhere on top of the valve cover.
Teal2nnr
35
Mar 30, 2015 07:46 AM
Initial_r90
Member Unresolved Disputes
40
May 7, 2014 01:42 PM
fubisd
Apr 23, 2014 05:14 PM
LOWPROaero
41
May 20, 2013 12:01 PM
siegelracing
For Sale - Cars For Sale
48
Oct 13, 2011 08:58 AM
