stock turbo redhot
Old Jan 24, 2009 | 03:13 PM
  #46
barneyb's Avatar
If you are lean then that will cause knock. Knock will retard the timing and retarded timing caused the turbo to glow. I think that about sums it up.
Old Jan 24, 2009 | 04:18 PM
  #47
robogast's Avatar
I will be driving my beater until dyno day.
Old Mar 12, 2017 | 01:35 PM
  #48
Mevouae's Avatar
sorry to resurrect thread but how did your glowing red problem get solved? Was it just tune or something else?
would be great help with your reply.
Old Mar 12, 2017 | 03:35 PM
  #49
4G63_EVO's Avatar
Ive seen it happen, on my 8 with 9 turbo when I use to go up angeles crest after driving hard id pop my hood and it would be fully glowing, but it would have to be pitch black for me to see it. My friend with his bone stock X would get the same thing. Its normal to an extent.
Old Mar 13, 2017 | 12:56 AM
  #50
RightSaid fred's Avatar
It's normal for them to glow with a high load on them.........check out youtube.
If it's glowing at idle, it's insufficient timing advance.
When it's dark, you'll see a glow that you won't see in daytime.
Old Mar 13, 2017 | 01:00 AM
  #51
Mevouae's Avatar
thank you guys, will be retuning with different tuner soon, let us see how that goes, will post my issues and how it was solved. Would be great if the OP sheds light on how his problem was solved.
Old Mar 13, 2017 | 10:12 AM
  #52
LetsGetThisDone's Avatar
Is this even serious? Turbine housings and exhaust manifolds get red hot. It's what happens when the exhaust gases traveling through them are over 1500* at WOT.
Old Mar 13, 2017 | 12:33 PM
  #53
But EGT is less than 700 F when idling and not many people get to look at a turbo when it's under full load.
They cool down quickly when off boost.
Old Mar 13, 2017 | 02:15 PM
  #54
4G63_EVO's Avatar
Originally Posted by Slo_crx1
Agreed 100%. Unless you are making stupid ridiculous amounts of power at high boost pressures there is no reason what so ever that your turbine housing should glow. I have never once had mine glow even after a number of hard runs to log and tune. And 13mpg is the dead giveaway right there, I still get in the low 20's fully tuned with normal driving.
how the hell do you get low 20s, I get 16 if im lucky
emperor496
Mitsubishi TC-SST Discussion
21
Sep 19, 2019 12:28 PM
dgutierrez079
Jan 16, 2018 08:18 PM
ToraEvoX
Nov 8, 2017 12:37 PM
Dmx3alo
Jan 28, 2017 07:45 AM
