whining noise when in gear?
Old Jan 22, 2009 | 07:35 PM
evo4life400's Avatar
hey guys i searched but want to explain this myself. when im in gear and low rpms the car is very whiny...its actually almost annoying. once i get to like 4k rpms which isnt often because i dont like beating on it the noise goes away...so basically i hear it constantly lol. its not so bad in fourth and 5th though. is this the transfer case, tranny or what? also for some reason from shifting from 1st to 2nd it gets like stuck a little...i almost have to force it. please tell me this is somewhat normal lol? thanks
Old Jan 22, 2009 | 07:37 PM
TheDream's Avatar
you can hear the t case in lower gear, you're ok.
Old Jan 22, 2009 | 07:38 PM
armaniranger's Avatar
sounds like you def need a new clutch and possible flywheel. i had a similar problem and happend to have a cracked flywheel. it happens so just get it checked out before you really hurt your car
Old Jan 22, 2009 | 07:43 PM
awsome....i just purchased the friggen thing and didnt hear it when i test drove it. but if i need a new clutch and flywheel...it wouldnt whine would it?
Old Jan 22, 2009 | 07:45 PM
mayday3k's Avatar
mine hums... which clutch you got in???
Old Jan 22, 2009 | 07:49 PM
uhhh...stock i think....unless the previous owner didnt say nothing
Old Jan 22, 2009 | 08:05 PM
markymark1082's Avatar
The evo's have a little whine in 1st gear. See if you can post a vid of the sound and we should be able to tell you if it is normal. You shouldn't have a problem shifting though. Before you go replacing your clutch, I would replace your tranny fluid and you should replace all the other fluids in the drivetrain while you are at it.
Old Jan 22, 2009 | 08:09 PM
yea...my wrx had this same noise too and i know my clutch was fine but it was only first gear so im not sure if it ok or not. i guess ill find out when i go and get my tune and my torque gets cranked up to see if the tranny is messed up
also ill try and post a video asap
Old Jan 22, 2009 | 09:05 PM
tsi20gawd's Avatar
The whine is loudest in 1st gear. It should be quieter in the higher gears.
Bryan
Old Jan 22, 2009 | 09:14 PM
def1's Avatar
my car whines in gear as well. In 3rd to 5th its pretty hard to hear tho
Old Jan 22, 2009 | 09:16 PM
Bora's Avatar
Mine whines in first and gets quieter in 2nd then is pretty much gone by 3rd.
Mine used to get stuck between 1st and 2nd really bad. I put in the Blox front roll stopper and shift bushings and it helped a ton. If yours is a really loud whine in higher gears I'd get that checked out.
Old Jan 22, 2009 | 09:51 PM
barneyb's Avatar
There's a "Somethings Wrong" whine and a "Gears are Happy" whine and they are not the same. My car has made the "Gears are Happy" whine since mile one. I hear it most in third gear at 30 mph and it is almost musical.
So, it depends, a whine could be bad or normal.
Old Jan 23, 2009 | 05:48 PM
mayday3k's Avatar
well i hope mine is a "Gears are Happy" whine, does anyone have a sound clip of this... I'm curious as to what this sounds like??
Kevin
Old Jan 23, 2009 | 06:23 PM
dbsears's Avatar
My MR whines in 5th and 6th on decel from about 65mph-45mph. I don't remember doing it until I had the dealer service my car. Stick in the clutch and its silent, engage the clutch and it comes back at those speeds. Anybody else had this (not trying to threadjack just figured I ask)
Old Jan 27, 2009 | 11:34 AM
red evo8's Avatar
mine whines in only 1st, almost like a super charger lol.
va1k0s
May 31, 2016 10:36 AM
va1k0s
Mitsubishi TC-SST Discussion
May 19, 2016 07:57 AM
jyamona
Apr 11, 2012 06:02 AM
Codeman17
Nov 28, 2007 09:14 PM
sir lurks alot
10
May 9, 2005 09:22 AM
