WTF is happening
Old Jan 24, 2009 | 02:04 PM
  #31
migs647's Avatar
s'not mean (i know you're just kidding), but it's hard to diagnose cars just with a description. There are multiple things it can be... so we suggest the most probable and move from there. My guess is a boost leak or low compression.
Old Jan 24, 2009 | 02:07 PM
  #32
justa4banger's Avatar
i hate the word "low compression"
Old Jan 24, 2009 | 02:11 PM
  #33
migs647's Avatar
it's not that big of a deal. A million directions you can go if that happens . Who knows you might find it fun to tear apart the engine and rebuild it. Perhaps just a ring upgrade will fix it.
  #34
evil-evo's Avatar
what were ur e.ts of the runs before andafter ur sixty foot of before and after. and u still runnin e85 and what did u change in ur tune
Old Jan 24, 2009 | 02:12 PM
  #35
markymark1082's Avatar
Like I told you yesterday, do a boost leak test and stop speculating. Let us know the results of the boost leak test and maybe we will be able to help you from there.
Old Jan 24, 2009 | 04:59 PM
  #36
Ok we did a compression test and the numbers are good 158 158 158 162....we did a boost leak test and did not have any leaks at all....now that I rember if it means anythng yesterday was humid really humid cuz it had rained during the morning..... but I mean this thing in the street is nutz...so idk...
Old Jan 24, 2009 | 06:06 PM
  #37
If you haven't already, get EvoScan and a Tactrix cable and log a few runs. See if you are getting any knock.
Old Jan 24, 2009 | 06:21 PM
  #38
i have the service engine light to flash if it knocks...and it does not knock..
Old Jan 24, 2009 | 06:22 PM
  #39
im goin to the track in a bit...ill let u know how it goes
Old Jan 24, 2009 | 06:23 PM
  #40
how many counts of knock do you have it set up to flash?
Old Jan 24, 2009 | 08:49 PM
  #41
bbyevo8u's Avatar
does your tuner set your cel to flash when it knocks?
is it hard to use evoscan?
Old Jan 24, 2009 | 08:54 PM
  #42
bluebyu36's Avatar
Originally Posted by evo@24psi
Damn! We sound alike with our set-ups old/new. I dont even know if a Boost leak can hurt THAT bad! Check the Turbo and make sure there is no shaft play and that the blades arent damaged.
well if u had a boost leak it would run pig rich no?wright there is enough...
Old Jan 24, 2009 | 11:35 PM
  #43
starts flashing at 4 counts..... and i went to the track tonite again, and still couldnt run better than a 12.7 at 111mph...another guy thats has a evo 9 wit a fp green and s2 cams couldnt trap higher than 114mph...so that made me feel better...mayb the track just suks...i will be goin to a different track next week end...
Old Jan 24, 2009 | 11:37 PM
  #44
ouch, good luck
Old Jan 25, 2009 | 09:52 AM
  #45
thepoint4life23's Avatar
have you thought about a bigger fmic.
