Glowing Manifold
Old Jan 26, 2009 | 07:59 PM
EvoIIIAj's Avatar
Glowing Manifold
Hey guys.
My friend started his Evo III today after some very long down time. The bottom end was rebuilt, so was the head. It was down for a bout 6 months and today was the first day it started, he drove it home very soft after it was started and noticed that the turbo manifold was glowing when he opened the bonnet..
Any ideas on what could have caused this?
Old Jan 26, 2009 | 08:08 PM
Kracka's Avatar
That sounds very odd with gentle driving. What manifold and turbo?
Old Jan 26, 2009 | 08:10 PM
sikrsix's Avatar
Doesnt seem right like ^^^ said with light driving. Is the cat clogged?
Old Jan 26, 2009 | 08:16 PM
EvoIIIAj's Avatar
Stock Evo III 16G
Stock Evo III Manifold.
I'll ask him to check about the cat.
Old Jan 26, 2009 | 08:17 PM
555R's Avatar
running a little rich? stuck open injector
Old Jan 26, 2009 | 09:07 PM
03ah8's Avatar
i thought if you were running rich, egt's were cooler. lean = higher egt's. that would also cause fuel fouled plug(s). correct me if im wrong. just trying to help narrow things down.
Old Jan 26, 2009 | 09:20 PM
Dapper Dan's Avatar
this is correct
Old Jan 26, 2009 | 09:26 PM
SLO-EVO's Avatar
you know, we had this same issue with a car / turbo setup that wasnt ran for a few months... he drove the car light for a few more times, and everything seemed to go back into place... it may be because the car hasnt been driven for a while? wondered about this myself, but the car fixed itself... try checking the plugs? see what color the tips are???
less10's Avatar
As well as not enough timing.
Old Jan 27, 2009 | 03:20 AM
EvoIIIAj's Avatar
Thanks for all the ideas guys!
Will definitely be checking everything today.
Old Jan 27, 2009 | 04:10 AM
AEvo2Nv's Avatar
Lol thanks guys. Thanks aj! Will deff try to get this sorted out.
Ill try and get the timing checked out today. Then try some different spark plugs wires and check the plugs a little later on when I get off of work.
Old Jan 27, 2009 | 06:40 AM
SloRice's Avatar
If its running to rich, it could be dumping fuel into the exhaust manifold where it auto-ignites on the hot manifold. This can cause the manifold to glow as well as potentially cause higher EGT's.
Old Jan 27, 2009 | 08:18 PM
EvoIIIAj's Avatar
The cam angle sensor got messed up 6 months ago when the car went off the road, so the timing was messed up. Put a new one on and he's fine!
Thanks guys
Old Jan 27, 2009 | 09:08 PM
555R's Avatar
kinda like what slorice said
but usually we like glowing manifolds...meaning youre boosting like an MFer
two203
Dec 17, 2011 03:52 AM
Travisty
Lancer Troubleshooting
Sep 3, 2011 01:18 PM
Kaotikkaos
North Texas Evo Club (NTEC)
16
Apr 9, 2010 10:02 PM
areet
Oct 12, 2004 11:11 AM
