IC sprayer problem
has anyone actually done testing to why this doesnt work? i hear ppl say it doesn nothing all the time just wondered if it has been tested
i believe only 2003 evos have that switch. maybe another owner changed the cover off an 03 and dont even worry that thing is really pointless and will not do anything for you
Not true. I have an '06 with the sprayer (JDM), maybe the USDM evos didn't get it, but it definately is there on my car. OP, try to remove the center console, it's really easy just 2 screws in the hole where the armrest is, then you can confirm if the plug is there, if not, then it's just the console off of an evo with the sprayer.
Mine hasn't worked since I replaced the intercooler, but in the qtr mile I would trap about 1/2 mph faster, when I started spraying in 4th gear. I would also think in the hot summer, it would help against heat soaking, when it comes on automatically.
I have the tank for the intercooler under the hood, the sprayers in front of the IC and the light in the dash above the lancer in the gauge cluster. I guess ill have to tear the console apart to find the wire. lets say there isn't a wire under there what do you think they did?
It doesn't matter if it's needed or not, he is saying everything is in there but the wires to the switch aren't, if his car came with it why not use it? OP I think you should look for the plug under the console, it's very doubtful that the previous owner cut the plug, is there any way you can contact the previous owner and ask him what happened? Let us know
GBAILEY472
Dec 9, 2010 04:37 PM
WickedMRsiNY
Sep 17, 2010 11:35 AM
