Bosch 1000cc injectors on an Evo
Old Nov 21, 2009 | 12:48 PM
  #346
TTP Engineering's Avatar
Originally Posted by mrfred
Two things:
1) For everyone: I haven't had time to do a thorough followup test, buy my initial test of relieving the fuel pressure in the rail until just before starting seems to stop the issue. Can a few other people try disconnecting the FPR from the rail and leaving it disconnected until just before trying a warm start?
2) Can someone build and send me a voltage divider that converts 16 V to 5 V so I can log voltage at the injector?
I saved you this test a month ago.
https://www.evolutionm.net/forums/7660874-post211.html
Old Nov 21, 2009 | 12:49 PM
  #347
CMB's Avatar
CMB
Originally Posted by JohnBradley
The ID2000s do not have this problem that I have encountered.
Interesting. If someone knows the reason behind that, we would be closer to the answer. I wonder if the other brands of this style injector have this problem? I wish I had the technical savy to help!
Old Nov 21, 2009 | 01:03 PM
  #348
JohnBradley's Avatar
I personally have only played with 2 sets of ID1000s and they were on gasoline. I didnt notice any of the issues others are having. The FIC 900 is another modified high impedance injector and those we tested on E85 and havent had any similar issues.
Debatable at this point still I think.
Old Nov 21, 2009 | 01:39 PM
  #349
mrfred's Avatar
Originally Posted by TTP Engineering
Yep, I remember reading that. That could be an indicator that its residual fuel pressure keeping the injectors closed, but how does that fit with the fact that a car will fire right up 5-10 minutes after shutdown when fuel pressure is still high?
Old Nov 21, 2009 | 01:41 PM
  #350
mrfred's Avatar
Originally Posted by 0xDEAD
You will need high precision resistors for best results. If you do a 330 ohm in series with a 100 ohm and tap in the middle with the 100 ohm connected to ground and the 330 ohm connected to VCC, that knocks down the voltage by 0.3125 or 14 volts will look like (14*0.3125) = 4.375,
So just two resistors in series running to ground? That makes sense.
Old Nov 21, 2009 | 05:23 PM
  #351
0xDEAD's Avatar
Two resistors running to ecu sensor ground, that way you don't have a floating ground skewing your readings. Still be aware that when cranking you might have a ground loop issue causing an "issue" and you are not actually getting a "result".
Old Nov 21, 2009 | 05:50 PM
  #352
Shawnmsr's Avatar
Has anyone used the 2000's for 93 Oct? Can you still get it to idle right with the stock ecu? I want to run E85 eventually and don't want to buy 2 sets of injectors.
Old Nov 21, 2009 | 06:03 PM
  #353
In 5-10 minutes the fuel pressure reduces in the rail 5-15psi.
Old Nov 21, 2009 | 07:15 PM
  #354
mrfred's Avatar
Not on everyone's car. I'm using the front O2 ADC to log a Kavlico pressure sensor attached to my fuel rail. The first plot in this post shows that fuel pressure in my car holds at 43.5 psi for a full 30 minutes after shutdown:
https://www.evolutionm.net/forums/ev...ml#post7667397
My warm start issues start picking up about 60 minutes after shutdown where the rail pressure has finally dropped to about 30 psi. I'm not dismissing the possibility that its a fuel pressure issue, but there needs to be another piece to the puzzle, such as warm injectors not having enough umph to overcome fuel pressure, for it to make sense.
The way to test this is to:
1) Relieve fuel pressure by pulling the FPR from the rail immediately after shutdown and leaving it disconnected until just before attempting a warm start.
2) Leave the FPR attached to the rail at shutdown. Pull the FPR just before attempting a restart (and then reconnect it) to relieve fuel pressure.
If its a leaky injector, #1 will help but #2 will not. If its a lack of ability of the injector to open (possibly due to fuel pressure, hot injectors, or something else), then possibly #1 and #2 will help.
Old Nov 21, 2009 | 08:00 PM
  #355
R/TErnie's Avatar
Mr. Fred,
I tend to think the leaky injector theory is the BEST theory yet... I'll do your 1-2 test and see what I come up with.
Old Nov 21, 2009 | 08:10 PM
  #356
If its a leaky injector, #1 will help but #2 will not. If its a lack of ability of the injector to open (possibly due to lack of fuel pressure, hot injectors, or something else), then possibly #1 and #2 will help.
I've run this test, only with a Fuelab FPR. It won't start, you crank it down 10 psi and it will start first time.
Old Nov 21, 2009 | 08:54 PM
  #357
Yes I have been doing this for the last couple months on both the FIC2150 and the ID2000. On a fuel system with base pressure set at 43.5psi it will even run on the O2 feedback if you insist on having it on.
Old Nov 21, 2009 | 10:44 PM
  #358
mrfred's Avatar
Can you explain in a more detail what you did?
Old Nov 23, 2009 | 12:46 PM
  #359
Shawnmsr's Avatar
Thank you for your help.
Old Nov 24, 2009 | 08:16 AM
  #360
travman's Avatar
I will try and get this taken care of over the holiday weekend - time / weather depending.
I have done this before and it always seemed to start much better but I didn't leave the FPR off until time to restart....I just unbolted it, relieved the pressure and then re-installed it and let the car sit for like 30-45 min but it did always seem to start much better.
