re-adjusted clutch pedal.
Old Feb 3, 2009 | 01:47 PM
sblvro's Avatar
Originally Posted by pjb00stin
ok!good thanks sblvro!!!problem im getting is sometimes just normal driving i get 2nd gear lockout.
if your clutch is resting close to the firewall floor, I would just lift it with my left foot and that should raise the engagement point of the clutch and prevent 2nd gear lockout(when cold I assume).
Old Feb 3, 2009 | 03:03 PM
j14mp's Avatar
HMMM>..good point.how many threads of the rod are showing through the little bracket.
I actually have mine almost maxed out so not very many threads are showing which I'm sure is ok as long as I don't push the pedal allllllll the way to the firewall. As the clutch begins to age I think you'll find yourself adjusting it further and further. I have the XDSS so I'm not sure if that makes a diff. but id say it's a significant amount more towards the top then the stock placement that is if you haven't adjusted it from the clutch install.
Old Feb 3, 2009 | 03:07 PM
j14mp's Avatar
my car was perfect until a few track runs and launches then I had 3rd to 4th lock out then weeks later 2nd to 3rd started to lock out then before i knew it, all the gears were locking out even during normal driving and especially at 8k rpm until i did the adjustment. It's def progressive.
Old Feb 4, 2009 | 07:07 PM
Mr. Evo IX's Avatar
When a single disc is overheated it can cause it to warp. A warped disc will require more clearance to allow a clean shift.
Panda_stunter
Jul 27, 2012 10:14 AM
bnr34rb26dett
10
Jun 5, 2012 11:47 PM
ambystom01
Lancer Tranny/Drivetrain Tech
11
Apr 21, 2010 03:34 PM
Toxin
16
Aug 28, 2008 03:45 PM
SlowCar
May 1, 2005 11:36 PM
