Tomei Full Turbo Kit Install........
Old Feb 26, 2009 | 05:07 AM
  #61
MACH3EVO's Avatar
here in AUS we got 245 kw at 24 psi this was using the TOMEI 260 deg mivec cams on a evo 9
i too
Old Feb 26, 2009 | 06:55 AM
  #62
fugiwara's Avatar
want to see pump gas results
Old Feb 26, 2009 | 08:15 AM
  #63
kaymin's Avatar
i too
That's 333hp is this the turbo and cams or just the cams? Seems low to me
Old Feb 26, 2009 | 08:40 AM
  #64
Black99Gs-R's Avatar
Sick setup!
Old Feb 26, 2009 | 09:03 AM
  #65
evo ippo's Avatar
i think it might be just cams on a evo 9 turbo and it also depends on the dyno they are using
Old Feb 26, 2009 | 09:12 AM
  #66
evo ippo's Avatar
ok for the updates I finally book the first tuning session it will be on March 7, hopefully my injectors are coming in. Ill be running the current set up which is bolt ons, turbo and injectors and ill show the forum members 91 octane and also 105 octane ( Thanks to Shawn with Domo-Speed for introducing Torco Race Fuel concentrate) which ill be mixing 5 galllon of 91 octane and 1 quart of Torco concentrate to yield 105 octane so it will be pretty good comparison. I included a video that tells you more about Torco Fuel concentrate on the bottom i think personally it a great substitute to paying for $7-$8 per gallon for 100 octane when these quart size bottles are pretty cheap and portable lets see the results first before we jump to conclusions
http://www.youtube.com/watch?v=XN0lyafkVGU
Old Feb 26, 2009 | 10:28 AM
  #67
midlifecrisis's Avatar
Good luck and thanks.
Old Feb 26, 2009 | 02:17 PM
  #68
MR. Tim's Avatar
In for 91 results.
Old Feb 27, 2009 | 04:49 AM
  #69
Exciting News's Avatar
Did those cams come with cam cards? Can't find any hard data other than peak lift.
Old Feb 27, 2009 | 08:09 AM
  #70
evo ippo's Avatar
Yeah it did come with a cam card let me see if i can take a picture and show it to you guys
Old Mar 3, 2009 | 09:09 AM
  #71
evo ippo's Avatar
As Requested
Attached Thumbnails Tomei Full Turbo Kit Install........-tomei-mivec-270-spec-sheet.jpg
Old Mar 3, 2009 | 09:12 AM
  #72
evo ippo's Avatar
Torco Race Fuel Concentrate
Look what arrived yesterday
Attached Thumbnails Tomei Full Turbo Kit Install........-torco-race-additive-001.jpg   Tomei Full Turbo Kit Install........-torco-race-additive-002.jpg   Tomei Full Turbo Kit Install........-torco-race-additive-003.jpg
Old Mar 3, 2009 | 09:32 AM
  #73
Thank you for those specs. Good luck with the build. I look forward to seeing your progress.
Old Mar 3, 2009 | 12:33 PM
  #74
March 7... March 7... Good luck.
Old Mar 4, 2009 | 08:18 AM
  #75
evo ippo's Avatar
doing a boost leak test today make sure everything is tight on the car and getting the evc setting correct for the new turbo man i can't wait till this weekend
