Tomei Full Turbo Kit Install........
Old Mar 6, 2009 | 08:00 PM
  #106
sparky's Avatar
Is the TOMEI install kit necessary? I realize that the kit accompanies the turbo when you purchase. But, I guess that the factory hard lines don't fit with the larger TOMEI comprssor housing. Or, will the stock IX lines work?
Old Mar 6, 2009 | 08:34 PM
  #107
Trader Vic CT9A's Avatar
looks nice, how does it feel?
Old Mar 6, 2009 | 09:20 PM
  #108
aka.ralliart15's Avatar
Pm Diirrk....I believe he's the only one with the turbo actually installed and running good at the moment.
Old Mar 6, 2009 | 10:52 PM
  #109
midlifecrisis's Avatar
Originally Posted by evo ippo
hey there
Well an update I decided to go with Naji and Looney Tune , Alot of friends had great reviews about Naji and I can't wait to see what Naji can do with the Tomei arms turbo so cross your fingers
Good choice. I think they favor EBC over MBC, right?
Old Mar 6, 2009 | 11:23 PM
  #110
evo ippo's Avatar
from what i have read about Naji and Looney Tunes is that he uses boost pills and the ecu to tune the car, with great results to. For my car we are using the HKS EVC 6 with the tuning software I had great results on the Evo9 turbo where i remove boost taper completely
Old Mar 6, 2009 | 11:25 PM
  #111
evo ippo's Avatar
From what i remember the factory lines should work but it like an extra bonus that it come with hardware
Old Mar 7, 2009 | 05:12 AM
  #112
AJR-Coco's Avatar
pretty much i change the down pipe, manifold and o2 housing to Tomei the injector where upgraded to FIC 750cc injectors other then that the car has been the same since the last tune. For the second stage of this install im going to put in the following Tomei 270 mivec cams, Tomei Cam Gear, Supertech Dual Valve Springs, ARP head studs
Thanks for answering the question! Looking towards your finished project. I wanna do something similar when i get my Evo, turbo upgrade, but need to know what i should upgrade before purchasing a turbo kit...
Old Mar 7, 2009 | 11:54 AM
  #113
Thrilla's Avatar
Veteran: Army
Looking forward to the results on pump. Subscribed.
Old Mar 7, 2009 | 12:04 PM
  #114
GPTourer's Avatar
In for more info.
Old Mar 7, 2009 | 04:52 PM
  #115
evo ippo's Avatar
Originally Posted by GPTourer
In for more info.
ok here the update guys Naji and I ran into a problem first it was car lighther it wasn't getting any power , I don't smoke so never used it after pulling the center consol the culprit was a a burnt fuse. Next we tried reading the ecu it kept shooting back with no response , thought it was the battery because it has happen to me before when the battery was weak it would not let me read the ecu so we tried to charge it then drive it around to see if the alternator can charge it that didn't work so after an hour of trying we conluded that it might be the battery being one of the slim ones might be weak we decided to reschedual so I can put in a big battery and recurc the bov. Ok here comes the stupid stuff more on my behalf yesterday after fic sent over the latency numbers to the 750cc injectors I went to go compared it with my current map and my previous map tuned by shiv after I was done I decided to flash in the map tuned by shiv but what I didn't remember was that shiv map had the ecu lock code. That why it kept kicking back an error message and the thought of running the ecu unlocked never cross my mind. So an hour I tried then like always I downloaded the map that sorry guys so results will come in 2 weeks Naji got a track event next week so stay tuned
Old Mar 7, 2009 | 04:58 PM
  #116
Reefer650's Avatar
The raised letters on the turbo look sic
Old Mar 7, 2009 | 09:04 PM
  #117
fugiwara's Avatar
now we have to wait for 2 weeks?!
Old Mar 7, 2009 | 09:14 PM
  #118
Oooooh noooooo.
Old Mar 19, 2009 | 04:20 PM
  #119
houdini_178's Avatar
Lordy Lord.... :0
Old Mar 21, 2009 | 06:12 PM
  #120
jsdude's Avatar
any news on the turbo? dyno graph vs red?
