Tomei Full Turbo Kit Install........
DLL reads very similar to a Mustang when it's setup properly. Razorlab did a comparison between DLL and his Mustang some time back and they were pretty close. An actual chassis dyno is more consistant because everything is controlled compared to being on the road where you have wind, grade, etc that can skew your numbers.
https://www.evolutionm.net/forums/ec...ml#post5814251
These are the first pump gas numbers with this turbo that I've seen.
What was corrected? You dont have correction turned on for either graph? Was the weight / gear ratio not correct for the 6 speed in your first graph?
If the DLL reads like a mustang dyno then i should be at 400whp on a dyno jet , Right?
Number wise so far know , but i know for sure my old set up netted me 325whp on 91 oct. and with the new tomei turbo it says I am netting 346whp on 91 which is hard to believe because the car is just a monster. I'm happy with how the car respond and how powerful the car is.
I am not to fimiliar with the DLL but what ive looked up there to many thing that could have been calculated wrong or not accurate so ill wait for the dyno jet to see some comparable results
