Tomei Full Turbo Kit Install........
Old Mar 5, 2009 | 08:19 PM
  #91
AJR-Coco's Avatar
Looking nice!
Old Mar 5, 2009 | 09:10 PM
  #92
sparky's Avatar
Nowadays, people like to run the bigger nozzles. It makes sense, especially if E85 might be in your future. Go for the 1000's, for sure!
You can hold off on the double pumper until you actually decide to use E85 depending on whether or not it is available in the area that you should move to.
So, go ahead and upgrade to the 1000 c.c. injectors when you swap out your stock turbo for the TOMEI ARMS. With the 1000 c.c. nozzles and the Tomei ARMS, the single WALBRO will serve you well both on pump gas and Q16. But, once you start running Ethanol, then you 'll probably want to install a double pumper.
Old Mar 5, 2009 | 10:07 PM
  #93
evo ippo's Avatar
hey there
Well an update I decided to go with Naji and Looney Tune , Alot of friends had great reviews about Naji and I can't wait to see what Naji can do with the Tomei arms turbo so cross your fingers
Old Mar 5, 2009 | 11:27 PM
  #94
fugiwara's Avatar
Originally Posted by evo ippo
hey there
still looking at March 7? get it tuned already
Old Mar 5, 2009 | 11:44 PM
  #95
evo ippo's Avatar
yes sir
Old Mar 6, 2009 | 12:55 AM
  #96
AJR-Coco's Avatar
Just a question, what did you upgrade when u installed the new tomei turbo? like engine wise? changed studs? gasket? ecu?
Old Mar 6, 2009 | 01:17 AM
  #97
fcapistran's Avatar
Hey bro question for you, do you have to mess with the map to use the torco accelerator for you to be able to use it or you just add that to the 91 octane pump gas and ready to go without switching your map to it? I want to try it and see the difference. thanks.
Old Mar 6, 2009 | 07:09 AM
  #98
aka.ralliart15's Avatar
Originally Posted by CWiLL
Marco@BilletDesign has the only order for the ones comming to the US as of now. You can call him if wanting one
(954-975-3557)
yea i checked u are right CWILL....and marco is a pretty cool guy, I cant wait to get this turbo already
Old Mar 6, 2009 | 07:15 AM
  #99
I think i phrased my answer wrong, I already had 1000cc injectors as i run E85 right now on the stock turbo, the reason I got the Tomei was to have around the same power and spool that I have now but on pump gas. Although we don't know what this turbo makes on low boost and pump I'm sure we can all agree that It's better than the FpGreen in both spool and power....only time will tell though but I expect great quality from a company like tomei.....but you are right though, you can hold off on he double pumper with the 1000cc if you don't run E85.
Old Mar 6, 2009 | 07:59 AM
  #100
fugiwara's Avatar
Are there any proof out there to prove the Tomei Arms is better than Green besides the E85 tune from AWDmotorsport?
Old Mar 6, 2009 | 10:27 AM
  #101
I plead the fifth...lol how many tests do you need though?? only a couple people have this turbo and thats why I stated "only time will tell though but I expect great quality from a company like tomei" just ask Diiirk himself how it feels compared to the green, im pretty sure he is satisfied with the switch.
Old Mar 6, 2009 | 10:37 AM
  #102
koey03's Avatar
nice!
Old Mar 6, 2009 | 10:54 AM
  #103
CWiLL's Avatar
I dont see any reason y it isnt. better housing design, similar size wheels in the turbo and no core charge.
Old Mar 6, 2009 | 03:30 PM
  #104
evo ippo's Avatar
pretty much i change the down pipe, manifold and o2 housing to Tomei the injector where upgraded to FIC 750cc injectors other then that the car has been the same since the last tune. For the second stage of this install im going to put in the following Tomei 270 mivec cams, Tomei Cam Gear, Supertech Dual Valve Springs, ARP head studs
  #105
evo ippo's Avatar
pm replied
