Help: misfiring under boost
Old Feb 7, 2009, 04:43 PM
emagdnim8's Avatar
(problem solved.)
Old Feb 7, 2009, 04:47 PM
emagdnim8's Avatar
Mods..feel free to move this thread to the advanced engine section...I'm not exactly sure which section is more appropriate.
Old Feb 7, 2009, 04:54 PM
emagdnim8's Avatar
I also wanted to add that the car idles fine, and runs normally until I'm boosting in the upper rpm's
Old Feb 7, 2009, 04:57 PM
Nightjoker7's Avatar
Have you tryed to gap the plugs and if so what at?
Old Feb 7, 2009, 05:24 PM
emagdnim8's Avatar
They were new oem plugs that come pre-gapped. I didn't gap them.
Old Feb 8, 2009, 02:46 AM
emagdnim8's Avatar
bump
Old Feb 8, 2009, 05:49 AM
TIBOevo's Avatar
pre-gapped so. you should always check the gaps anyway. i would measure the gaps from the old plugs and use that gap size. what kind of plugs?. ngk bpr?
Old Feb 8, 2009, 10:44 AM
ya you always check plugs you never just put them in check them they should at the very most be at .26 I would almost bet money that's why your cars running like it is.
Old Feb 14, 2009, 10:27 AM
emagdnim8's Avatar
You would've lost some money in that case
Old Mar 5, 2009, 08:31 AM
spdrcr456's Avatar
So what was the problem. This thread helps no one. People search that might have the same problem. This thread is usless.
Old Mar 5, 2009, 08:16 PM
LV///R's Avatar
Yeah, what was the solution?
I'm having a similiar issue. My car "hesitates" VERY slightly anywhere from one to three times while hitting full boost. I'm just wondering if my plug wires are shot. I've changed my plugs, changed my BOV back to my stock one just to make sure, and it still does it. Very annoying!
There are absolutely no other symptoms, other than an EGR code P0401 which I highly doubt has anything to do with this?
Old Mar 11, 2009, 11:11 PM
IX-Is-Mine's Avatar
You can't gap iridium plugs for ix anyways. So that kind of throws that solution out the door. You have stock ignition too? And what was the problem?
