What would I need...
Old Feb 10, 2009 | 10:43 AM
SilvrEvoIX's Avatar
I'm planning on purchasing a BBK turbo and wanted to know what else should I need for this turbo to run it's best.
My current mods are:
AMS FMIC
AMS LICP
AMS TBE with MIL.SPEC 100 cell cat
AMS MBC
Vibrant adapter with K&N filter
Old Feb 10, 2009 | 11:12 AM
thepoint4life23's Avatar
Injectors fuel pump and a tune
Old Feb 10, 2009 | 01:54 PM
justa4banger's Avatar
cams, injectors,headstuds, better bov, and definitily a clutch to hold that power and a good tune
Old Feb 10, 2009 | 01:57 PM
SilvrEvoIX's Avatar
So if I'm changing injectors I gotta change the fuel pump? I've heard you really don't have to change the fuel pump on a IX. So what injectors would I get. Im also planning on using the stock ECU.
Old Feb 10, 2009 | 02:12 PM
depends on what fuel and how much boost your planning on doing...a fuel pump is a cheap safety mod...
Old Feb 10, 2009 | 02:17 PM
inco9nito99's Avatar
Get:
FIC1050cc injectors.
Cosworth m2 or Kelford 272/272 cams (Kelfords i'd recommend supertech valvetrain) w/ARP headstuds.
Atleast a single plate Exedy clutch.
FMIC.
T-bolts on stock pipes.
Fuel pump (as insurance).
Forge DV.
Perrin intake -stock pipe.
MIL.SPEC 100cell cat.
...tune .
Old Feb 10, 2009 | 03:03 PM
SilvrEvoIX's Avatar
Thanx Kunal. You'll be my last stop for the famous Kuniiizzzeee Dial-IN! If everything goes to plan, I'll see you in the summer . BTW, just found out that my cat is a MIL.SPEC 100 cell cat.
Wayne Brewer
May 27, 2016 04:55 PM
thomasman
May 9, 2011 07:39 PM
HuMmInGBiRd
Nov 2, 2010 06:11 AM
Josh083188
10
Mar 30, 2010 05:59 AM
ClubLancerDFW
Lancer Aftermarket Forced Induction Tech
12
Dec 2, 2002 05:10 PM
