5th Gear problem
Old Feb 10, 2009 | 03:15 PM
HarEvo's Avatar
Question 5th Gear problem
when im in 5th gear and on the gas and let off i can feel a vibration and sounds like a ripped axle, you can hear it when the music is off.
any suggestions? need tranny fluid? tranny gone? 5th gear needs to be replaced?
thank you
Old Feb 15, 2009 | 11:31 AM
armyfoodsucks's Avatar
is the sound a thud or similar to a clunking sound?
Old Feb 17, 2009 | 05:32 PM
HarEvo's Avatar
its difficult to explain. when im in 5th gear going highway speeds and let off the gas it sounds like a clanking sound but not loud like i can feel the transmission gear rattling and causes a vibration and sounds something like when a car doesnt have enough tranny fluid so it sounds dry. i was thinking maybe it was the syncro for 5th of low on tranny fluid.
sorry i cannot explain the sound further just sounds like rattling and is kinda rough for 4th and 5th gear when accelerating then letting off the gas.
Old Feb 27, 2009 | 03:44 PM
xav's Avatar
xav
maybe its the transfer case....
Old Feb 27, 2009 | 04:33 PM
monkey_187's Avatar
Check your fluids ASAP, I have a friend that his transfer case reservoir was empty now he needs a new pump and tc. I would start there cause if it is something small like that you will end up spending BIG bucks to get it fixed.
Old Nov 10, 2009 | 01:24 PM
HarEvo's Avatar
drained and put in new transfer case fluid but 5th gear still doesnt engage.
couple mechanics told me it might be as simple as a syncro.
reverse works SOMETIMES and 5th gear has quit on me. syncro problem or 5th and reverse gears are bad? and ideas?
Old Nov 10, 2009 | 02:07 PM
mifesto's Avatar
I have a similar issue. In 5th gear I get a low constant vibration. I have exede twins so it makes it worse. I'm having ivey find out what I need
Old Nov 11, 2009 | 12:49 PM
HarEvo's Avatar
mine did the same thing before it went out. id go to a tranny shop and find out before your 5th gear quits on you like it did to me. good luck and lmk what the tranny shop says it is, it might be the same thing that happend to me
Old Nov 11, 2009 | 04:08 PM
mifesto's Avatar
what did you replace in your tranny?
Old Nov 11, 2009 | 04:16 PM
190hpkilla's Avatar
i recommend http://www.dogboxracing.com/
I had Shep build my trans which lasted 3K miles. Sent it out to them and they treated me like gold! 2 of my other friends have solid 9Sec DSM and use his trans.
Old Nov 12, 2009 | 10:01 AM
HarEvo's Avatar
didnt replace anything in the tranny 5th gear and reverse just quit, i never grinded or slammed gears either. does dogbox deliver cuz 825 is deals!
Old Nov 14, 2009 | 06:17 PM
mifesto's Avatar
so you got a new tranny simply cuz your 5th gear quit?
Old Nov 16, 2009 | 10:14 AM
HarEvo's Avatar
no transmission has NOT been replaced or worked on its STOCK and 5th and reverse went out
ralliart425
21
Apr 9, 2017 08:57 AM
GreeceS13
15
Jul 21, 2014 06:46 AM
pb91
Jun 8, 2011 02:44 PM
SleepySamurai13
15
Apr 29, 2009 12:53 AM
thuan
Jul 12, 2007 03:15 PM
