Trasfer case question
Old Feb 12, 2009 | 09:59 AM
Timmay81's Avatar
Im sure its out there but i cant find anything with the search.
Can i use a 2005 Transfer case in a 2003 evo? I know the 05+ has the active control or whatever you call it.
im sure it would bolt up but will this work properly?
Old Feb 12, 2009 | 10:01 AM
ev0lution9's Avatar
you mean ACD..im pretty sure you can use it and take the ACD controls out and it should work i could be wrong though.
Old Feb 12, 2009 | 10:13 AM
Timmay81's Avatar
maybe im wrong. is it 04+ or 05+ that has acd?
Old Feb 12, 2009 | 10:15 AM
evil_eagle's Avatar
05+ had ACD. 03 and 04 used the same t-cases.
Old Feb 12, 2009 | 10:24 AM
Timmay81's Avatar
lol i try not to bug you to much and you still end up answering my question
Old Feb 12, 2009 | 10:32 AM
sr20det91's Avatar
You can use it..obviously its gonna be locked in the default mode which I believe is tarmac. You will have to plug the fluid hole in top where the line from the ACD pump taps in though.
FWIW the 04 RS' had ACD as well as the 05 and up models.
Old Feb 12, 2009 | 10:36 AM
Evoryder's Avatar
04RS does not have ACD it has Front LSD like 05'+ evo's. That's the difference between it and the regular GSR 03/04Evo 8's.
I have an 04RS Transfercase in my 03 evo. Same thing.
Old Feb 12, 2009 | 10:51 AM
sr20det91's Avatar
I stand corrected..i was just about to edit my post when u chimmed in.
Old Mar 23, 2009 | 07:04 PM
Timmay81's Avatar
can anyone verify this?
i want to put a 05 TC into my 03
will it work with just plugging up the ACD stuff or will it not work properly?
Old Mar 24, 2009 | 07:31 AM
Timmay81's Avatar
i know someone has this answer
Old Mar 24, 2009 | 01:55 PM
xLaNcErEvOx's Avatar
+1 someone please verify...
SloEvo12
May 4, 2016 08:53 AM
EvoXSMC
Apr 10, 2011 09:23 AM
Boostme
Northwest Region
Feb 9, 2011 05:24 PM
krazykorean84
Nov 30, 2008 07:21 PM
DrivEvolution8
Feb 4, 2007 08:26 AM
