View Poll Results: Did you Tee into the FPR line or the bov line for your boost gauge?
FPR Line
45.45%
BOV Line
54.55%
Voters: 11. You may not vote on this poll
Boost Gauge. FPR or BOV
Old Feb 14, 2009 | 08:37 PM
EvODavO's Avatar
Which hose did you -T- into for your Boost Gauge, The Fuel Pressure Line or the Bov to intake manifold line? I hear that if you tap into the FPR line and the hose pops off under boost u can blow up your engine from running to lean? But most people that I have talked to still seem to be running thier gauges from the fuel pressure line. Is there any Pros/Cons to either such as more consistant and accurate readings or quicker response?
Old Feb 14, 2009 | 08:47 PM
EJW2202's Avatar
I used the fuel pressure line. If you connect everything correctly you shouldn't have to worry about it blowing off.
Old Feb 14, 2009 | 09:19 PM
19DB794's Avatar
I would also tap it off the FPR but luckily I have an MR so I simply tapped into the factory boost gauge vacuum line.
Old Feb 15, 2009 | 05:13 AM
Smike's Avatar
I run it off the DV/BOV line. Reasons: If it does come off - no harm done. And you are pulling away a small amount of air from the FPR. If I had a choice on what I would rather pull air away from - its going to be the BOV. The function of the BOV < function of the FPR.
Old Feb 15, 2009 | 05:21 AM
Psquared's Avatar
My stock MR gauges were tapped into the FPR hose.
Old Feb 15, 2009 | 05:26 AM
edardnaekim's Avatar
In the dv line here. When i was tee-d into the fpr, some times my gauge wouldnt read rite away and it got annoying..
Old Feb 20, 2009 | 05:22 PM
EvODavO's Avatar
switched sources today from fpr to BOV line and I seem to have more vacuum pressure, other than that no noticable differences
Old Feb 20, 2009 | 06:56 PM
Davo's Avatar
^^make sure and use plastic tie straps on the hose and yes that is the one to use
write up in install page documented this install
Old Feb 21, 2009 | 03:56 PM
EvODavO's Avatar
Bump
Old Feb 21, 2009 | 04:33 PM
EvODavO's Avatar
Any1 else?? I know all you guys are running boost gauges! Please share where you tapped your source. Seems like we have alot of people Teeing into different sources. Maybe Ill put up a poll to see what the majority of you guys are taping into.
Old Feb 21, 2009 | 05:08 PM
sphinxof2006's Avatar
i used the bov it was recommended by Speed Element for me but u can use the FPR
Old Feb 23, 2009 | 09:41 PM
EvODavO's Avatar
Bump.. for more replies
Old Feb 28, 2009 | 03:42 PM
EvODavO's Avatar
poll posted, please vote!
Old Feb 28, 2009 | 04:09 PM
URBANRCR's Avatar
Bov line for the same reasons others have posted.
ghoonk
13
May 28, 2021 01:53 PM
Erik@MIL.SPEC
E85 / Ethanol
Nov 11, 2008 12:46 PM
ghoonk
Apr 16, 2008 09:42 PM
Jumperalex
Oct 18, 2004 08:42 AM
Siyah
11
Feb 22, 2004 08:40 PM
