Budget 2.3L Stroker Questions
Old Feb 24, 2009 | 05:41 PM
  #46
ScorpionT's Avatar
Originally Posted by Tonba
If I went to the GT3082R but threw a 0.82 housing on it, how laggy would it be?
As I said, im looking for quick spool, but I dont want it falling over up top...
A bit more laggy than the 3076, it might do ok. How much power do you want to make and how hard do you plan to run your turbo?
Will you be using meth?
Old Feb 24, 2009 | 07:07 PM
  #47
Tonba's Avatar
No meth, no race fuel. ONLY pump on either a 2.2L or a 2.3L.
Not interested in top end power, I want full boost (22~25psi) no later then 3800, and I dont want it falling over at 7000~8000rpm..
Old Feb 24, 2009 | 09:33 PM
  #48
ScorpionT's Avatar
That should do alright for what you want. Ive never done a setup exactly like that, so I cant say for sure what it will do. If its not quite what you want when its done you can always change things, like the turbine housing, compressor, etc...
Old Feb 24, 2009 | 09:49 PM
  #49
esevo's Avatar
I would look into Jackson Auto Machine. They do international orders all the time!
I have there Stage 3 2.3L and its AMAZING! I also have a AFI twinscroll Gt35R with this setup I get full 20 psi at 3800 rpm!!! I will be sending the turbo out for the HTA treatment for even faster response. Transient boost response is flat out great with the TS!
Dont go cheap, save if you have to, you will be glad you did!
Good Luck!!
Evan Smith
Old Feb 25, 2009 | 12:35 PM
  #50
Tonba's Avatar
Ok all. Here is the run down.. Ill be getting the following
-APC 2.2L Stroker Kit
-Ti Retainers & Valve Springs
-Port & Polish Head
-Haltech E11V2 (with 3 Bar Map Sensor)
-Custom Exhaust Mani, Custom Dump Pipe, Custom Front Pipe
-Garrett GT3076R with a 0.82 Rear Housing
This should get me all my goals.. 25~28psi @ 4000rpm with a safe 8000rpm redline..
Old Feb 25, 2009 | 01:35 PM
  #51
ScorpionT's Avatar
Whats the cost on the APC stroker? Any idea on what kind of rods they use?
Old Feb 25, 2009 | 01:57 PM
  #52
Tonba's Avatar
^ Well, there is actually three stages of stroker kit they make. I will be going for the basic kit.
Thier basic kit is AU$3,400.
Stage 2 is AU$4,350.
Now, the difference between these two kits is that the basic uses off the shelf JE pistons and thier own 150mm rods & crank.
Stage two uses 163mm rods and custom pistons. It has a better rod ratio..
Beemen550
Jan 12, 2015 02:21 PM
Sj119808
Dec 24, 2014 05:42 PM
IN IDLE
Jan 20, 2014 08:15 PM
Alchem1st
35
Dec 3, 2013 05:35 PM
InsaneSpeed
22
Nov 28, 2011 06:46 PM
