Question about intercooler spray on 04 Evo GSR
Old Apr 24, 2009 | 01:58 PM
  #31
rsboy's Avatar
Originally Posted by l EVO n
lol what if you put a type of fluid (other then water)wich would make the air in the intercooler even more cold that should make a diffrents
you don't use water on the IC sprayer, you use washer fluid. Water would freeze during winter and such. Straight methanol will destroy the hoses and plastics, I would assume. I took my tank off just recently and will probably put some kind of hose to direct air up to the filter. I never really used it for DD, but I had it on auto during track days.
Don't really know if it made too much difference, but it did a little bit. You could see the temp gauge lower down when it sprayed on the IC. Some people claimed it helped a little when they had their cars on the dyno. But honestly, it's cool but you aren't really missing out on much. I'd rather have ACD and Super AYC to replace the IC sprayer.
Old Apr 24, 2009 | 02:18 PM
  #32
oneofakindtrini's Avatar
probably overflow..
Old Apr 25, 2009 | 05:27 AM
  #33
l EVO n's Avatar
what u mean the evo 8 doesnt have Super AYC and ACD???
i thought it did , and dat would be sweet if i had that on my car and i didnt use it like ppl here clame they dont for sure i would tweek it to point infront of me so when some girls passed by squirt them , infact i might just tweek my windsheld sprayers to squirt at some girls when they pass infront of me at red lights
Old Apr 25, 2009 | 05:28 AM
  #34
l EVO n's Avatar
so 2 be honest im missing out on alot
Old Apr 25, 2009 | 01:48 PM
  #35
sonicnofadz's Avatar
I just removed mine and sold it on ebay. Dead weight imho.
Old Apr 30, 2009 | 01:11 PM
  #36
MinorThreat's Avatar
i wonder if you can rig it to cool the turbo instead
Old Apr 30, 2009 | 03:49 PM
  #37
boozeup&riot's Avatar
Originally Posted by GT-One
As mdesi said, use washer fluid to prevent freezing in the winter, that reservoir design is not my favorite, as its kind of trial and error to fill (when it starts spilling you know its full). The IX dropped the sprayer since the hydraulic reservoir for the dif. occupies that real estate. On a hot summer day, for us 8's the sprayer is bound to provide at least a small benefit to intercooler.
I wonder if the redesign of the front air dam on the IX offers as much (if not more) of a benefit - would be interesting to see any some info on this: evo VIII vs IX stock intercooler air temps or what not. I just figured that in order for the sprayer to be really effective it'd have to be on A LOT.
Old Apr 30, 2009 | 07:10 PM
  #38
I assume its not very useful because if you are driving it the air would simply dry it off before actually making any difference? So the comparision would not be all that helpful.
Old Apr 30, 2009 | 07:46 PM
  #39
barneyb's Avatar
All the talk about the sprayers not being effective comes from the car magazines that tested the Evo back when it arrived on these shores.
They'd run the Evo through the quarter mile with the sprayer on and with the sprayer off and not see any difference in the times. Well, you know they weren't holding the button down for continuous spraying because you can't do that and shift gears. So, whether the sprayer was running or not was controlled by the ECU. It may not have been spraying at all depending on what conditions the ECU was seeing.
In my opinion, what the sprayer is for is to control knock when conditions are hot. Less knock means more power. If you aren't heat soaked then it probably does make no difference.
Old May 1, 2009 | 02:46 AM
  #40
l EVO n's Avatar
whats a knock?
Old May 1, 2009 | 04:33 PM
  #41
barneyb's Avatar
whats a knock?
Your kidding - right?
Old May 27, 2009 | 05:09 PM
  #42
billyblonco's Avatar
If the water sprayer's are so useless why do they still use them on the overseas evo X also?
http://www.mrtrally.com.au/performan...IX-ICSpray.pdf
Old May 28, 2009 | 03:55 AM
  #43
Benz04GSR's Avatar
whats a knock?
The Dictionary.com definition...
KNOCK (nok)
v.
v.tr.
1. To strike with a hard blow.
2. To affect in a specified way by striking hard: knocked the mugger senseless.
3. To cause to collide: I knocked my head on a low beam.
4. To produce by hitting or striking: knocked a hole in the wall.
5. To instill with or as if with blows: We tried to knock some sense into his head.
6. Slang To find fault with; criticize: Don't knock the food; it's free.
v.intr.
1. To strike a sharp audible blow or series of blows, as on a door.
2. To collide with something: knocked into the table.
3. To make a pounding or clanking noise: The car engine is knocking.
n.
1. An instance of striking or colliding; a blow.
2. The sound of a sharp tap on a hard surface; a rap.
3. A pounding or clanking noise made by an engine, often as a result of faulty fuel combustion. Also called ping.
4. Slang A cutting, often petty criticism.
Old May 28, 2009 | 04:28 AM
  #44
Benz04GSR's Avatar
It's not useless... ANYTHING that lowers the temperature of air passages will lower the temperature of the air. Like my man said, reducing heat soak and knock in the process.
Tibbar
Nov 14, 2013 04:18 PM
adammartini
Sep 7, 2009 03:59 PM
flyguycfi
13
May 11, 2009 03:31 PM
Gutievo
Jun 10, 2008 01:04 AM
BlueEvo04
Oct 12, 2004 10:30 AM
