clutch job need help!!
Old Mar 7, 2009 | 05:19 AM
Malik_EvoIX's Avatar
just got clutch job done a cci stage 4 clutch with oem resurfaced flywheel 200 miles on it still breaking it in granny driving. when car is at a stop engage in 1st gear giving car gas letting clutch out a moaning noise like a elephant occurs but goes away when car is in motion. it is a little loud. when i am cruising shifting trough gears the noise never occurs.
*Finally got the video clips*
http://videos.streetfire.net/video/E...ise_640908.htm
http://videos.streetfire.net/video/I...ice_640909.htm
Old Mar 7, 2009 | 05:38 AM
Chemwarrior's Avatar
Was your throw out bearing replaced while your clutch was replaced?
Old Mar 7, 2009 | 05:41 AM
yes everything was replaced. this is what i bought: https://www.evolutionm.net/forums/ve...der-400-a.html (STAGE 4)
Old Mar 7, 2009 | 05:59 AM
a buddy told me i will hear weird noises till fully broken in. but never heard a noise like this.
Old Mar 7, 2009 | 06:05 AM
vmrevo9's Avatar
Veteran: Air Force
i just did my ACT clutch too and there are some noises to. it might be just the breakin. i have 200 miles on mine to and the noise i get is upon cold startup. once warm it goes away. this might be normal as of what i am told. just follow your breakin procedures and you should be fine.
i havent launched mine or taking off hard but i do get on it from time to time to while the car was already rolling. it grabs hard and and doesnt let go lol.
Old Mar 7, 2009 | 06:08 AM
yeah my clutch grabs amazing. i am driving like a grandma. the noise is loud like a elephant screaming. happening now when i went up my driveway. but this doesnt happen all the time. if i let the clutch out fast the noise doesn't happened. i am really paranoid!!!!!!!
Old Mar 7, 2009 | 06:09 AM
eponti's Avatar
did you adjust the clutch pedal after the install ?
Old Mar 7, 2009 | 06:11 AM
vmrevo9's Avatar
Veteran: Air Force
try adjusting the pedal that is good advice i would think. i'm pretty sure its normal until break in.
BTW that was a good price on that clutch kit!
Old Mar 7, 2009 | 06:13 AM
2 days ago i had my guy do it. but i think it isnt engaging i have to give it effort to put it in reverse. But sometimes this noise is scaring me!!! my last clutch job i never had a noise while breaking in it was a fidanza 2.1
Old Mar 7, 2009 | 06:18 AM
vmrevo9's Avatar
Veteran: Air Force
try readjusting the pedal it isnt to hard to do www.evomoto.com has instructions on how to do it.
i think the noise has to do with the material of the clutch.
Old Mar 7, 2009 | 06:31 AM
i am sure it's adjustment. when cruising shifting trough gears the noise never happens. only when the car is at a halt then moving
Old Mar 7, 2009 | 06:44 AM
yeah the guy at the shop was playing around with the pedal to find the proper engaging point. from there he engaged it.
Old Mar 7, 2009 | 07:16 AM
birdmanVIII's Avatar
i used to have a exedy twin carbon in my car and it used to make alot of noise too....thy told me that it would not go away its jst the down side of having a good clutch....hopefully it just needs to be broken in
Old Mar 7, 2009 | 07:17 AM
sti owner told me this: the release bearing Fork, or maybe i gotta wait till i put 500 miles on it still breaking it in. 300 miles to go. the noise never happened the day i took the car out for the shop thus i went out for a 15 mile test drive..........
Old Mar 7, 2009 | 07:31 AM
05EvoVIII's Avatar
No worries man it is normal. id go 700miles on the break in also. My fadanza 4 puck came with a paper saying to go 700 miles on break in. whats another 200 miles ya know
just give it a couple days and as the miles go up on the clutch the noises should start going down.....they will never go all the way away tho lol its an evo
