Evo 8 to Evo 9 Turbo
Old Mar 10, 2009 | 05:53 AM
whoang40's Avatar
Originally Posted by Fast_Freddie
Just did this this weekend. I ordered an install kit from mitsubishiparts.net, and bought some additional crush washers as their kit doesn't come with all of them, nor does their kit come with a manifold to hotside gasket. I also had to buy the gasket for the oil drain line on the turbo side.
You don't have to replace the metal manifold to hotside gasket, just reuse the old one like I did. This includes the metal gasket between the hotside and O2 housing.
Old Mar 10, 2009 | 08:57 AM
worksevo89's Avatar
Registered User
Thanks guys for all the great info!
Old Mar 10, 2009 | 10:08 AM
mnr12's Avatar
So would I need a new oil drain line if the 9 turbo didnt come with one?
Old Mar 10, 2009 | 10:11 AM
ace75's Avatar
How much more are you expecting to gain going from an 8 to 9 turbo?
Old Mar 10, 2009 | 10:36 AM
sslevo's Avatar
20-30 hp on the top end is pretty common. It holds more boost to redline.
Old Mar 10, 2009 | 10:40 AM
MitsoKid's Avatar
going to a 9 or an 8 with 10.5 hotside (is there any difference?) and i'm also gonna be running a meth setup with a nitrous intercooler chiller kit should open up some ponies
Old Mar 10, 2009 | 11:36 AM
abazaba410's Avatar
yeah bigger intake side on the evo 9 turbo. its a 20g. but ill let some one more knowledgable comment more.
Old Mar 10, 2009 | 12:30 PM
DDATuned's Avatar
Stock 8 return line works on the evo 9.
I wouldnt waste the money on another install kit. If I had to do it all over again I would just buy a new oil feed line , oil return line gaskets and a compressor pipe. Re-use everything else from the evo 8. The water lines can be bent and its not much bending at all. The feedline could probably be bent as well but i just wouldnt change getting a crimp in it.
Anyway good luck.
Old Mar 10, 2009 | 03:37 PM
Fast_Freddie's Avatar
Veteran: Navy
The 05 VIII 10.5 hotside and the IX 10.5 hotside are exactly the same... I learned that this weekend as the 9 turbo i purchased had a broken stud and a stripped hole... I just swapped my 05 VIII hotside to the 9 turbo of course after some port work
Old Mar 10, 2009 | 03:41 PM
Veteran: Navy
Anyway good luck.
Also I did have to trim one of the rubber coolant hoses by about 1/2 inch to keep it from kinking...
Old Mar 10, 2009 | 03:44 PM
Veteran: Navy
I could have reused it cause it looked fine, I am just **** and don't like doing stuff twice if I can avoid it... especially taking apart the turbo section again because I skimped out on buying a gasket...
Old Mar 10, 2009 | 07:19 PM
MitsoKid's Avatar
so are they the same turbo? if so i should be able to make ~360awhp with my setup and a new tune.. or so i have been told... i was also told that the 05 evo 8 turbo had the 9.8cm^2 nozzle and not the 10.5??
Old Mar 10, 2009 | 07:34 PM
sslevo's Avatar
Re-read that, the 10.5 hotside is the same from 05-06. The IX or 06 turbo had a larger compressor. A IX turbo will make 10 or so hp more than a 05 with the 10.5 hotside. The IX turbo will make 20+ more hp over a 03-04 turbo with the 9.8 hotside.
Old Mar 10, 2009 | 07:47 PM
MitsoKid's Avatar
thanks for clearing that up.. so it looks like i'm in the market for a IX turbo
TURBO_S2K
12
May 1, 2016 05:54 PM
Deano_Engineer_
Mar 6, 2014 05:57 AM
5LEEPERISAH23I
15
Jul 14, 2009 09:50 AM
ellyottlin
Apr 26, 2009 06:27 AM
IVERSON3270
15
Jun 1, 2007 12:40 PM
