Crank Pulley FELL OFF WTF!!!
Old Mar 9, 2009 | 08:50 PM
scheides's Avatar
EvoM Moderator
Same thing happened to me last winter! Roughly 40k miles, stock bottom end, stock belts, no stock undertray.
Ended up spending $800 at a no-name sinclair shop getting a new timing belt cog and crank pulley, mine was completely gone. I am 99% sure I hit a chunk of ice about the size of a fist. I had just done a pull or two and then ka-thunk!
I tried to limp the car a bit and almost died on the side of the road.....worst day in the evo evar.
Old Mar 9, 2009 | 08:55 PM
igo4bmx's Avatar
i had an accessory pulley just fall off and the bolt sheared in half- all while at a stop light lol
Old Mar 9, 2009 | 08:58 PM
TTP Engineering's Avatar
This is more common than you would think. Definitely not a rare occurence. Its happened to a number of folks we know including our own ATi unit broke all 6 bolts! Which is why we will never recommend this product, instead the Fluidampr.
Old Mar 9, 2009 | 09:05 PM
05EvoVIII's Avatar
I have the fluidampr on my evo now....
Old Mar 9, 2009 | 10:31 PM
biggie5252's Avatar
My new pulley is also a fluidampr.
Old Mar 10, 2009 | 06:37 AM
mugen777's Avatar
I wonder if it would benefit to go with a light pulley.. like UR... but you have the harmonic damper or balancer argument. It clearly makes power and dyno graphs I have seen show a increase of 10-15 whp and torque, is it worth it?
Old Mar 10, 2009 | 08:04 PM
deathtracks's Avatar
Not unless you like harmonics of cranktwist. Long term the UR pullies are bad news. Flywheel bolts and pulley bolts tend to back off and microcracks can start leading to damaged cranks, etc.
Old Mar 10, 2009 | 08:11 PM
VRSF Tiago's Avatar
A good indicator of the bolts backing out is occasional belt squeel/squeek.
Good thing the engine is ok though
Old Mar 10, 2009 | 08:22 PM
3K's Avatar
3K
How do you check the bolts? Can you see them from the looking down from the shock tower, or do you have to remove the wheel and check through the fender well?
Old Mar 10, 2009 | 09:14 PM
evovin's Avatar
Originally Posted by boosted2x2
sounds like someone played the hulk when they were tightning the bolts. good luck getting the broken pieces out and use a torque wrench on the new bolts.
Did the bolts fell off or broke off?
I thought he said fell off as title says
Old Mar 10, 2009 | 09:48 PM
EVO_RYAN's Avatar
man this **** just happen to me same thing....
Old Mar 10, 2009 | 09:49 PM
EVO_RYAN's Avatar
wow the same thing happen to me bad luck i guess mine only had 38k on it.... and the tq is 18 lbs...
Old Mar 10, 2009 | 10:45 PM
Red loctite is used in the installation of any crank pulley by us.
We have Fluidampr's available if you want to replace yours with one.
Old Mar 11, 2009 | 04:08 PM
mugen777's Avatar
I will get with ya by the end of the week on ordering one!
and the bolts BROKE off into the harmonic balancer I tried to drill them out with a ez out and a left handed drill bit but its a no go!! I am going to go ahead and replace the timing belt ( even though I had to do that like 2 months back because it jumped teeth) and everything else while im at. I have 40k miles at the moment ... might as well
Old Mar 11, 2009 | 08:54 PM
and the bolts BROKE off into the harmonic balancer I tried to drill them out with a ez out and a left handed drill bit but its a no go!! I am going to go ahead and replace the timing belt and everything else while im at. I have 40k miles at the moment ... might as well
Just buy a new sprocket.
