Car problem after IC & intake install
Old Mar 11, 2009 | 04:40 PM
YNGEVO's Avatar
i just installed an ets 3.5" intercooler and switched from a hks intake to an ets intake. Now, when the car idles my AEM Wideband is reading all the way from below 10's to above 17's. Afrs are all over the place. And then when i drive car i dnt even have to get 50% on the throttle and afrs are low 10's. There must be a leak somewhere or a problem somewhere. The ETS ic and intake are brand new.
Please i would appreciate yals .02 cents.
Old Mar 11, 2009 | 04:44 PM
YNGEVO's Avatar
What if the Intercooler is leaking? Its brand new. used for 15miles.
Old Mar 11, 2009 | 04:48 PM
SixOneNine's Avatar
Did you plug the maf back in?
Old Mar 11, 2009 | 04:51 PM
YNGEVO's Avatar
lol ya. its all hooked up.
0E3vobutt3r's Avatar
+1
I just put the ets Ic on too and I started my car and was like WTF!? Lol as soon as I opened the hood I was like DOH.
anyway check that and do a mean boost leak test I found the smallest leaks everywhere. do yourself a favor and get a spray bottle with some soapy water.
That way you don't have to depend on your hearing, you will literally see the leak
Best of luck
Buddy
Old Mar 11, 2009 | 04:54 PM
YNGEVO's Avatar
thanks guys. do you just spray the bottle over all of the piping and see where is starts bubbling or something?
Old Mar 12, 2009 | 10:19 AM
abazaba410's Avatar
gl to you im trying to investigate a simular prob
Old Mar 12, 2009 | 03:53 PM
Yeah thats what I did worked out pretty good
Old Mar 12, 2009 | 05:14 PM
RoadSpike's Avatar
Its usually the intake that causes it to swing around wildly like that in my limited experience, especially if you have cams. Put the other intake on it for awhile or get the car tuned up the maf scaling and smoothing probably needs a touch up.
Old Mar 12, 2009 | 08:42 PM
YNGEVO's Avatar
is that what wld cause it to run super rich, when i am not even in wot?
Thanks,
Gared
Old Mar 12, 2009 | 09:16 PM
evokid511's Avatar
i dont think just an intake alone will cause your afrs to go all over the place like that... with my inatke at idel im at 14.something on my afrs
Old Mar 13, 2009 | 10:17 AM
YNGEVO's Avatar
so i obviously have a boost leak somewhere
Old Mar 13, 2009 | 10:54 AM
chaotichoax's Avatar
the intake will definitely play a role
the orientation of the maf pipe calls for different smoothing and scaling numbers
Old Mar 13, 2009 | 02:34 PM
RoadSpike's Avatar
Some intakes are better than others but there are other factors in here too.
I had my buschur intake and it works fine for a long time until i put my cams in. The cams just roughed up the idle enough to really make it swing around wildly. I put the stocker back on and it stopped.
If i get speed density on this car with the ECU patches out there I'll put the intake back on.
mithrandir7533
Nov 24, 2020 12:40 AM
kikiturbo
Sep 29, 2014 07:25 PM
Lucas English
Jun 26, 2009 11:47 AM
YNGEVO
Mar 23, 2009 11:23 AM
03redtype-s
10
Oct 6, 2008 08:28 PM
