35 R with full rase mani on stock motor with stock head studs?
Old Mar 14, 2009 | 12:13 PM
LION evo's Avatar
Will stock headstuds hold the boost from GT35r on Full race mainfold?
Old Mar 14, 2009 | 12:23 PM
WickedIXMR's Avatar
Nice spelling.
Old Mar 14, 2009 | 12:27 PM
Munch's Avatar
Originally Posted by WickedIXMR
Nice spelling.
Wow that post was helpful . Depends on your tune. If you get a crappy tune , the answer is no. I'm running a Buschur Racing tubular HTA37R kit @ 28psi, and my stock headstuds are doing just fine for over 4 months now .
Old Mar 14, 2009 | 12:29 PM
LION evo's Avatar
Nice spelling.
I don't care much about spelling. I was a bad schoolboy
Any answers to the subject?
Old Mar 14, 2009 | 12:30 PM
Munch's Avatar
Look one post up. I answered it for you.
Old Mar 14, 2009 | 12:31 PM
BocaShula's Avatar
you'll be fine
Old Mar 14, 2009 | 12:32 PM
LION evo's Avatar
are you running on stock ecu ?
Old Mar 14, 2009 | 12:35 PM
WickedIXMR's Avatar
Its called SEARCH. This topic has been covered plenty of times. Btw the stock head BOLTS arent studs.
Old Mar 14, 2009 | 12:37 PM
Munch's Avatar
Yup stock ECU
Old Mar 14, 2009 | 12:38 PM
ScorpionT's Avatar
Nice spelling.
Youre a pretty helpful guy, arent you? Hes from Ukraine so spelling should matter even less.
Yes, you can run 28psi with stock headstuds, even on stock ECU. Get a good tune and you will be good to go.
Old Mar 14, 2009 | 12:44 PM
LION evo's Avatar
Thank you for the replies.
I think it will be hard to find a good tuner in my area.
Old Mar 14, 2009 | 12:54 PM
EvoDan2004's Avatar
Nice spelling.
not something i expected from you at all. especially toward someone out of the county. way to go.
OP
you can run your stock bolts but like others are saying make sure your tune is spot on. i recommend jestr tuning and the Eflash's he offers. he is probably going to be your best bet. he is also one of the best tuners.
i do recommend you pull the valve cover off every once in a while to re check the trq settings on the bolts. this will insure you that there still tight and strong. and its free insurance. but i also recommend just changing the bolts out for ARP head studs. there about 100.00 bucks. and the 1x1 method can be done only if done right. hope that helps you.
Munch's Avatar
Good luck bro.
Old Mar 14, 2009 | 04:31 PM
LION evo's Avatar
OP
Thanks
kpt6
12
Jun 2, 2015 07:18 PM
CtSilver03Evo
Mar 4, 2011 10:39 AM
ETS Michael
ExtremeTurboSystems.com – WA
Mar 27, 2009 02:33 PM
sidtheretard
Aug 26, 2008 08:05 PM
ofb73
64
Jun 19, 2008 01:14 AM
