Competition Clutch Flywheel/Clutch Install on Evo IX RS
Old Jun 17, 2009 | 09:29 AM
dtuned's Avatar
Originally Posted by FX11
bleed your slave cylinder or do a pedal adjustment
The clutch swap king knows this better than anyone on here Just kidding, broham! I have been off line for a few days, so I don't know if you got the twin CC thing sorted out.
As per the comment about the two springs balancing out harmonics, there is some truth to it. I have known some owners who have doubled up on the springs when upgrading the clutch to an aftermarket one for the same reason mentioned here on the thread... to cancel out the noise. Try this if all the driving and breaking in stuff fails.
It's a wonder nobody has come out with an aftermarket clutch spring set.
Old Jun 17, 2009 | 06:18 PM
Steve-oEvo's Avatar
Hey I have a stock Evo IX RS, and im pretty sure the clutch and TO bearing are bad, when I drive it normal for over 20 min I can smell burning clutch and in nuetral I can hear the knock from the TO bearing would this have anything to do with why I cant rev the motor past 5,000 rpm from launch?
Old Jun 17, 2009 | 09:38 PM
BluEVOIX's Avatar
The clutch has nothing to do with the factory set 2 step and vise versa, except launching the car wears the clutch faster.
Well first of all your off topic. Although this thread is about a clutch but it pertains to a specific clutch and for a specific problem.
Ok well to help you out there are a few things you need to know about your car (Evo IX). The IX's came with a factory standing rev limiter (aka 2 step) of 5,000 rpms. So when you want to launch your car, you can not rev past 5,000 rpms and break stuff, but at the same time the rev limiter can help you launch the car because it acts as a 2 step launch control. All you do is push in the clutch rev to 5k rpms and hold a WOT position and maneuver the clutch to preload and moderately fast release to launch.
As far as your clutch, I would guess its time to change it. Have you noticed if the clutch is slipping when spirited driving? (during hard acceleration the rpms rise faster than mph)
Old Jun 18, 2009 | 07:05 PM
FX11's Avatar
lmao no i still gota find my problem, im dropping the tranny 2nite =]
as for the problem, it might be the spring, def do the pedal adjustment man
and for the other guy with his stuff burning, take it back apart and do the right torque settings, and shave off 1mm off your pressure plate to make it level throughout
Old Jun 19, 2009 | 02:43 AM
dtuned's Avatar
Good luck, bro! I gotta do some work today on the EVO with replacing the select lever shoe. Part finally came in, and since the car has been sitting for a while, I gotta bleed the lifters. No fun, but it's mandatory.
A honing stone works well with shaving the feet of the pressure plate. That and a lot of WD-40 and patience.
Old Jun 19, 2009 | 03:37 AM
MR Turco's Avatar
Originally Posted by S2kracka
It'll hold WAY more the 350whp though. I'm on the Stage 3 @ ~400whp and its holding great.
should be talking torque not hp.
jd888jd
May 4, 2016 04:35 PM
Vivid Racing
Sep 13, 2010 11:49 AM
m0nkie
12
May 2, 2010 06:03 PM
SBR INC
Apr 30, 2010 06:58 AM
KazzEvo8
11
Sep 12, 2006 08:53 AM
