Blew seals on newish FP Red?
Old Mar 18, 2009 | 08:02 AM
Boltz.'s Avatar
FCOTM Winner
Originally Posted by smokedmustang
Sorry, had different visual after reading thread title. LOL
I never knew old guys were funny! That was a good one.
Old Mar 18, 2009 | 08:04 AM
naudlee's Avatar
ebay trash.... quite possibly
Old Mar 18, 2009 | 08:21 AM
PVD04's Avatar
Originally Posted by Evolessfornow
I thought that shaft play meant bad bearings not bad seals. So bad seals would lead to shaft play too?
No, but bad bearings can lead to damaged seals. It seems likely that your problem may be due to excess crankcase pressure. The easiest thing to do at this point would be to check that none of the hoses going to your catch can are clogged. Another possibility is that your oil return flow is restricted in some way.
Old Mar 18, 2009 | 08:30 AM
idriveanevo's Avatar
an fp red???
Old Mar 18, 2009 | 08:31 AM
scheides's Avatar
EvoM Moderator
+1 on checking the crankcase vents.....is there oil in the compressor inlet?
Old Mar 18, 2009 | 09:28 AM
sk8terdude929's Avatar
Correct me if im wrong but white smoke would be a coolant leak not oil, Oil is usually blue smoke. Have you done a leakdown test, or checked the head gasket?
onlynamenotused
15
Oct 13, 2018 11:48 AM
SikEvo8
Oct 26, 2008 08:31 AM
heygotboost
Mar 11, 2008 10:11 AM
rcheung
Nov 5, 2006 08:40 PM
mikiblueeyes
Jul 5, 2006 09:31 PM
