ACT 6 puck sprung guys ???'s for ya
Just installed the ACT 6 puck sprung kit and the ACT 10 LBS flywheel..
When taking off from a stop light or any stop and go the car like shutters/chatter. The car drives great in all gears, It's only when taking off....
Is this just because it is a race disk?
Is this what they mean by harsh engagement/chatter?
How far did you have to adjust the pedal out?
i have my engagement almost all the way out at the end of the pedal. i recomend the solid shift cable bushings and a solid front motor mount. it helps prevent the 4th gear lockout that most of us have had.
the shutter you are speaking of is where you are trying to slip the 6 puck. they don't like to slip. if you get your rpms up a little and let it out a little faster the shutter should go stop happening. there is a balance between letting it out too fast and creating "harsh engagement" and too slow and it shuttering. i recently (about 3 months ago) installed a 6 puck with light flywheel in my DD and it took several weeks to get used to the engagement.
I have an ACT sprung 6 puck just put in with the 13lbs flywheel. Is it bad for the break-in of the clutch to rev a little to much or shutter? I'm just worried about breaking in the clutch properly
Lucas English
184
Feb 5, 2017 10:37 PM
