the EXHAUST thread
Old Dec 13, 2005 | 02:23 PM
  #721
C6C6CH3vo's Avatar
Originally Posted by davidbuschur
OUR CATBACK if you order the SCCA catback has a flange that will bolt to the stock cat or anyone's offroad pipe.
Is the diameter of the SCCA CB stay 3" at the flange where it meets the cat delete pipe (my catdelete is full 3"), or does it taper down to the stock cat converter diameter?
Old Dec 13, 2005 | 02:29 PM
  #722
shadow1's Avatar
This has been answered at least twice in this thread. By myself and Mr Buschur. There are NO neckdowns.
Old Dec 13, 2005 | 02:42 PM
  #723
C6C6CH3vo's Avatar
Sorry, I ask because I was told different
Old Dec 15, 2005 | 02:45 PM
  #724
David Buschur's Avatar
Yes, the flange is full 3". We use NO reducers or resonators in our exhausts.
David Buschur
www.buschurracing.com
Old Dec 16, 2005 | 02:38 PM
  #725
DevilsEvo666's Avatar
Hey dave, Im buying an 06 GG IX MR very soon...and If i buy a muffler would it be possible to make an 3 inch exhaust for evo 9 or is it a lil different than the 8? I found a muffler from australia and its a 3 inlet all the way with carbon fiber body, with a slant cut titanium flamed tip...The company that makes it is HyperTech Racingcraft performance mufflers.....Any idea how much it would be to make the pipes and send it out?
Old Dec 16, 2005 | 02:54 PM
  #726
I'd need to know the dimensions of the muffler you are trying to use. I'd rather use ours.
David Buschur
Old Dec 17, 2005 | 06:36 AM
  #727
EvoIXMR's Avatar
David -
Do you have 3.5" SCCA cat-back (flanged) and is it the same design and layout with a buschur muffler and what the price on it may be? I didnt see the 3.5 listed on the site....
People opt for Ti for the weight reduction and 85mm piping, but with the buschur 3.5" SCCA system, its comparable weight and price may be quite compelling to buy it instead!
Thanks!
Old Dec 19, 2005 | 07:01 AM
  #728
I don't know if the muffler you found will work or not, I don't like to build our sytems using other mufflers.
The SCCA catback is only 16.3 pounds with our BR muffler on it. That is 20 pounds less than stock.
The 3.5' exhaust is quite a bit heavier than the 3". If you aren't making over 600 whp you don't need our 3.5" exhaust. I can build a 3.5" SCCA flanged catback but it would neck down to 3" to go to the stock cat.
David Buschur
Old Dec 21, 2005 | 06:22 AM
  #729
Bigoj2's Avatar
What all do I need if I have the Authority downpipe and the turbo outlet and soon to get the Authority cat exhaust system?? Does is all bolt up with the factory Cat or do I need a new one or go without one?? Thankyou for your time
Old Dec 27, 2005 | 11:01 PM
  #730
ballistic speed's Avatar
Who ever started this thread, PLEASE UPDATE IT, and please leave clif notes besides each exhaust commenting on the quality, noise, construction, and stuff like that
Old Dec 28, 2005 | 09:11 AM
  #731
EVO Neil's Avatar
Originally Posted by e8
So here's a list of all the exhausts I am aware of:
Buschur
Vishnu
RMR
RnR
TurboXS
Perrin
AMS
AVO
HKS Hi Power
B&B
JIC
Greddy
Fujitsobo
Now, can someone order these from the one that makes the most power to least? And then order these from most quiet to least quiet (put the buschur with the magnaflow)? Now, I am giving all of these companies the benefit of the doubt and assuming their quality control is good enough where I don't have to ask to order these from the best to worst quality.
Here is one article that should help some. Older information, but still good.
http://www.tprmag.com/issue/5/5_turbo_exhausts.shtml
What about adding Ralliart, Works, and Magnaflow Ti to the list??
Old Jan 13, 2006 | 11:56 PM
  #732
MRG's Avatar
MRG
um hey i been reading this thead a lot and i was wondering if anyone would mind posting all or any true 3" tb that doesnt tapper down.
Old Jan 14, 2006 | 04:31 AM
  #733
EvoIXMR's Avatar
invidia, turboXS, buschur, RMR, Perrin, DC Sports when purchased as full TBE systems will not taper in the middle. There are others, but I am naming the ones I am sure....
Most JDM downpipes are 2.75 inches and/or taper at both ends - if you are doing a combo system, I would use a DP from the above for it!
Hope this helps!
Old Jan 14, 2006 | 06:18 AM
  #734
shadow1's Avatar
Other systems that do not neck down include Works, VRS, Vishnu, and maybe Helix. I believe all JDM catbacks neck down at the cat (HKS, RSR, Greddy, JIC, etc). Also Borla and Thermal neck down as well.
Old Jan 14, 2006 | 06:55 AM
  #735
alloyic_rs's Avatar
well they taper down for a reason, for instance my greddy ti catback tapers down at the cat flange, the whole piping is 3.15 inches and it tapers to 3 inches at the cat, most downpipes and test pipes out there are 3 inch in diameter so greddy ti tapers down to 3 in to fit the test pipe/cat
