4g64 and cam shafts
Old Mar 28, 2009 | 12:04 PM
UMSTuning's Avatar
did you make 215hp at redline or at 3500? What engine management?
Old Mar 28, 2009 | 05:37 PM
crcain's Avatar
I can't understand people running Evo timing belts and not degreeing their cams and such. Get the 4G64 DOHC belt.. I'll give you the part number if you need it. And degree your cams! The kits are cheap and it takes a bit of figuring out but well worth it!
Old Mar 28, 2009 | 05:38 PM
sonicnofadz's Avatar
You can always buy 4G64 cam gears and a 4G64 timing belt, the marks should line up perfectly using this.
Old Mar 28, 2009 | 06:29 PM
gotrnet's Avatar
this is definatly the easiest way to do it.
Old Apr 3, 2009 | 07:09 AM
malachi's Avatar
Old Apr 7, 2009 | 02:51 PM
malachi's Avatar
can anyone offer any more Suggestions, or if even my cams are causing this?
and if they are, what do i need to do, adv or retard which one?
thanks
Old Apr 7, 2009 | 03:45 PM
gotrnet's Avatar
what have you tried so far? there have been several suggestions and i just want to eliminate the ones that you have tried.
tim85851
34
Oct 29, 2017 05:58 PM
tscompusa
Apr 17, 2017 11:47 AM
Abacus
Feb 10, 2016 10:59 AM
Aby@MIL.SPEC
Dec 28, 2015 01:02 PM
arptunner
Lancer-Mirage Compatibility Forum
26
Jan 17, 2008 04:10 AM
