Problem after Clutch Install...
Old May 30, 2009 | 08:08 AM
  #31
dtuned's Avatar
Originally Posted by Dubai_EvoVII
i still have the same problem even when iam reving on stand still and ican can feel it in the stearing too ,i jast change the flay wheel ...?? please if any one have any idea
Revving while in neutral... so the shafts won't be turning/engaged... Go over all the mounts and make sure they are bolted in properly. The gearbox mount that is connected between the gearbox and the steering rack crossmember... I am willing to bet that it is not even bolted on. Did you do this yourself or did you have some shop in DBX do it? Check it, bro... I am fairly certain that is the cause of your worries. It it were the flywheel, you would have more sounds and other not good stuff happening. Good luck.
Old May 30, 2009 | 08:10 AM
  #32
musca999's Avatar
Originally Posted by blownevo
Ok guys, I finished installing my Exedy Stage 2 clutch and flyweel today and it drove fine. But after about 20 min of driving it started making this weird vibration almost like the driveshaft is off balance or something. Its like my tires are completely off ballance all of a sudden. I doubt it's my tires so what do u think it is?
It seems like IDK like the driveshaft is spinning off balance and its vibrating or spinning off a little and making the car shake a lil and giging off a bit of a low frequency hum. Almost like I have a Subwoofer in my car really loud with lots bass. It only happens after 50mph but before it's fine. And after about 75mph it calms down a lil but its still there. Also, once in a while I hear this loud thud from the rear of the car when I shift gears, and I wont even be shifting hard.. Like its a bang when the gear goes in from the rear diffy or driveshaft or something. IDK
PLEASE HELP!!!
This may sound really stupid but it happened to me. Did you make sure the wheels are on properly? I did work on my car once and when i put one of the wheels back on the lug nuts felt tight but the wheel wasn't really seated properly against the hub. This caused weird vibrations when driving and I couldn't figure it out either. Finally it came loose enough that it became obvious. Luckily it wasn't on the freeway :P
Old May 30, 2009 | 08:16 AM
  #33
dtuned's Avatar
Broham figured it out. The drive shaft wasn't firmly bolted in, as he said. As for yours, this is a good example of getting hub-centric rims/inserts so that one can avoid the issue of misaligned rim installation
Corey
29
Jul 25, 2011 04:20 PM
spooldursti
17
Apr 20, 2011 02:12 PM
m0nkie
12
May 2, 2010 06:03 PM
MTRJunior
39
Apr 18, 2009 02:12 AM
deegaw11
13
Feb 27, 2007 12:20 PM
