Which Engine Oil is the Best
Old May 31, 2010 | 07:04 AM
  #166
Discospeed's Avatar
Hey guys. I'm new to evom and currently am driving/racing an MSP which i've sold and have been wanting an evo 9 for over a year now and that's what I'm getting as soon as I find the right one. I'm just researching as much info as I can at this point and have done a bunch of reading before posting anything. Do the evo 9 trannies use a GL-4,75w-90 gear lube? Also it seems like from reading through this thread that most ppl that are DD/autox use a 10w-30 oil for the motor. Thanks and I know the search button is my friend I just wanted some personal feedback.
Old May 31, 2010 | 10:27 AM
  #167
Erik@MIL.SPEC's Avatar
If you're looking for an MR, the 6 speed transmission uses a 75W-85 GL-4. The 5 speed uses a 75W-90.
Old Jun 4, 2010 | 07:22 AM
  #168
Discospeed's Avatar
^Thanks man. Glad I asked.
Old Jun 4, 2010 | 02:42 PM
  #169
rodent's Avatar
Jacks suggest the 6 speed oil for the 5 speed along or Redline MT90. I think the other tranny builders also suggest Redline.
http://www.jackstransmissions.com/pages/oil
Old Jun 4, 2010 | 02:54 PM
  #170
TTP Engineering's Avatar
Amsoil MTG has worked great for our customers.
Old Jun 5, 2010 | 09:12 PM
  #171
-Jarred-'s Avatar
Originally Posted by MRfabolous
what about motul engine oil i heard that stuff is very good.
Wow, it took 11 pages before Motul got mentioned! Have a look at Motul 300v Competition
Old Jun 6, 2010 | 04:33 AM
  #172
kiggly's Avatar
In my engine Mobil1 has just barely delivered the best protection/wear for the main and rod bearings. This is compared to Pennzoil racing, Royal Purple, and Valvoline Racing. The Mobil1 is just slightly better, but enough to notice on teardowns. When I had some clearances a little too tight it was on a 1-track-outing inspection interval.
Kevin
Old Jun 6, 2010 | 04:46 AM
  #173
wreckless969's Avatar
Kevin
No experience with Castrol?
Old Jun 6, 2010 | 09:16 PM
  #174
rodent's Avatar
Kevin
Which weight?
Old Jun 6, 2010 | 09:47 PM
  #175
sparky's Avatar
Originally Posted by rodent
Which weight?
Yeah, I wonder the same thing.
Old Jun 6, 2010 | 10:00 PM
  #176
sparky's Avatar
Originally Posted by Giwrgos_77
Can i use the 10-60 Shell Helix Ultra?
I have used the 5W-40 Ultra and it held up well in the tropics. Ultra is Ferrari factory fill. However, I wouldn't run 10W-60 unless doing strictly sustained highspeed driving in extremely hot weather or on a built stroker motor with relatively loose tolerances.
The heavier weight oils do absorb more heat though. So oil temps will tend to be lower. I found this true when I ran Mobil1 5W-50. What I don't like about the 5W-50's and the 10W-60's is the spread between the upper and lower vicosities which requires higher levels of stabilizing additives.
Also, the thicker stuff tends to be a bit more problematic on cold startups and with the lifters.
Old Jun 7, 2010 | 07:03 PM
  #177
kiggly's Avatar
I have no experiences with Castrol. I run either 15w50 or 20w50.
Kevin
Old Jun 7, 2010 | 07:16 PM
  #178
TommiM's Avatar
my last car I ran agip 10w40, or 10w60. I cant remember, it was a while ago. I liked it, but was hard to get. For the price I would rather use amsoil anyhow, much better oil, imo.
Old Jun 9, 2010 | 04:50 AM
  #179
rodent's Avatar
Kevin
Okay, thats the racing M1, non-SM spec which has more ZDDP. Good stuff.
I still won't use any SM spec oil (10w-30, 10w-40) with the lower ZDDP content. Federal guidelines are suppose to regulate it to 800 max so your catalytic converter can last longer.
Old Jun 9, 2010 | 05:54 AM
  #180
Ted B's Avatar
Just to clarify, the Mobil 1 15w-50 you can buy anywhere carries an "SL" rating and contains 1200ppm ZDDP. The 0w-40 contains 1000 ppm.
