Getting ready to install evo 9 turbo into evo 8.
Old Mar 30, 2009 | 09:52 PM
Inflation's Avatar
I've been searching for the thread that shows the part numbers for everything I would need to put in an evo 9 turbo, manifold, hotside etc.
Can anyone link it for me please?
Don't flame.
Old Mar 30, 2009 | 09:56 PM
justa4banger's Avatar
all you need is the 9 turbo j-pipe and a 10.5 hotside....you can use the 8 turbo manifold and 8 turbo oil and coolant lines....
Old Mar 31, 2009 | 01:18 AM
Inflation's Avatar
Okay well I have the Evo 9 Turbo and the 10.5 hotside so I should be good to go? I got new gaskets also.
Old Mar 31, 2009 | 01:28 AM
whoang40's Avatar
I'd recommend getting new copper gaskets for the oil feed line.
Old Mar 31, 2009 | 02:08 AM
Inflation's Avatar
So which one of these should I pick up?
http://store.forcedperformance.net/m...Lancer-TurboHW
Old Mar 31, 2009 | 03:12 AM
ch53avitech's Avatar
I'd get the install kit (the $135 one). I don't believe in taking shortcuts by not replacing the lines. And while your at it get the turbo ported if you want to go all out.
Old Mar 31, 2009 | 04:19 AM
Gary@MellonRacing's Avatar
u need evo 9 turbo
evo 9 actuator , should buy 18psi if u will b running 18+ boost
the install kit to use the 9 turbo on an 8
when buying the install kit u need to specify if u want stock oem pipe or j race pipe for turbo
Old Mar 31, 2009 | 08:39 AM
all i did was use the lines from the 8 turbo, and i just bought the j-pipe and i used the stock copper washers because they looked good...but hey if you have the money to spend go ahead and do it...but i would get a 02 housing instead of that install kit if you do have the money....
Old Mar 31, 2009 | 08:46 AM
Boltz.'s Avatar
FCOTM Winner
Just need the turbo and the compressor outlet pipe.
Old Mar 31, 2009 | 09:39 AM
Fast_Freddie's Avatar
Veteran: Navy
The oil feed line and the coolant lines are a little different but can be bent (carefully) to fit. I would go ahead and invest in all new crush washers for everything, and new gaskets for the oil return line (turbo side and oil pan side), then a new IX J-pipe. I just did this swap about 2 weeks ago, and I bought everything from Russell at mitsubishiparts.net. he has the IX install kit listed on the site also if you want new everything, but his kit doesn't include all of the crush washers or the manifold to turbo gasket. I would also suggest spending a few extra dollars and picking up an ebay O2 housing while you have everything off cause that will definitely help you in the long run...
http://www.mitsubishiparts.net/catalog/?section=652 scroll all the way to the bottom of the page...
Old Mar 31, 2009 | 11:54 AM
Inflation's Avatar
Thanks for the help all!
evo9ben
Apr 22, 2017 12:29 PM
eisnikesb
Dec 7, 2016 08:46 AM
terfer
Jul 7, 2009 04:29 AM
bank277
Jul 24, 2008 04:02 PM
The442GTO
May 8, 2006 09:06 PM
