Evo Bolt-On 75mm Billet Throttle Body ( A MUST SEE PRODUCT )
#33
Thanks guys for all the positive feedback.
-mitdrx- These are currently available to the public we have 50 available.
-hokiruu- We Used the 5.0 bolt pattern because of throttle shaft leakage issues most aftermarket throttle bodies have. It will bolt up directly to a 5.0 pattern with no problems without having the throttle shaft leakage issues. However we also made tappered adapter plates so the will bolt up to a stock intake manifold flange as well. This TB was designed for use of a stock IAC which will keep drivability and idle control like stock but able to use a larger diameter TB. Its just another option that we have given to the evo community.
-addo- We will have gains/dyno #'s very soon.
