Bov........
Old Apr 11, 2009 | 10:21 AM
jdmuscle's Avatar
Bov........
Guys, I have been searching and searching.... cant corner my mind on which one to get for my 06 MR!!
-synapse DV
-Forge
-HKS
-Greddy
Please advise, need something quick to have my dyno session next week!!
Thanks in advance for all your help!!!
Old Apr 11, 2009 | 10:25 AM
bluebanana23's Avatar
most will say synapse or forge. Hks is not really compatible for evos for some odd reason but some has gotten to work with no additional work besides the recirc. kit. I had the greddy type-s before and all was great until the diaphragm tore after 20K.
Old Apr 11, 2009 | 10:26 AM
1320 Engineering's Avatar
leave the stock one on there
Old Apr 11, 2009 | 10:28 AM
stocker is great unless you plan to run more than 26 psi
MuslimEvoFreak's Avatar
+1 Stock MAF>Aftermarket BOV
Old Apr 11, 2009 | 10:29 AM
jmelocik's Avatar
Synapse because you will never outgrow it, it is adjustable to make it work for whatever application you have (fast spooling stock turbo, or laggier medium or large frame turbo at high boost). I bought mine when I was still on the stock VIII turbo and couldn't have been happier. Great DV, looks great, works great, holds boost no problem and I was finally able to get rid of the part throttle compressor surge. Contact Synapse for more details. I am still running the stock MAF as well with no problems.
Josh
Old Apr 11, 2009 | 10:31 AM
DJ Brett B's Avatar
Depends how much boost you wil be running- unless you are going to run high boost why not your stock BOV? Get a recirc unit if you NEED to replace it for one that handles upwards of 25psi... I just bought an APS twin vent which is a recirc unit, you should look into that piece as well
Old Apr 11, 2009 | 11:14 AM
jdmuscle's Avatar
Thanks for all the feedback guys, my car currently has a FP red and I am contemplating in running at least 30psi on race and 23-24 on pump!
While dynoeing the car last nite, the stock BOV was surging like no tomorrow.... hence the birth of this thread!!
Can I incoporate the synapse DV with the injen piping kit without any mods? I am pretty sure the answer is yes but I would like to confirm!
Once again, thanks for all you help members of EVOm
Old Apr 11, 2009 | 11:16 AM
jdmuscle's Avatar
APS twin recirc unit, someone did mention this one to me!! I will look into this as well! Thanks
Old Apr 11, 2009 | 01:31 PM
MarioTME's Avatar
IMHO go for synapse! i had the risk of ordering it all the way to the middle east, AND i never regret it! i tried HKS and the stock DV but the synapse DV is the Best ever. you wont imagine the response speed of the DV and the way it holds boost..
+1 Synapse for such a great product
Old Apr 11, 2009 | 04:05 PM
jmelocik's Avatar
I used the Synapse for a short period with my Injen intake and UIPC, it worked fairly well. Later on I upgraded to the Buschur stuff and it worked great there too. Just FYI the BOV doesn't surge, the compressor does, and it's very bad for the turbo.
Old Apr 11, 2009 | 04:09 PM
Jim in Tucson's Avatar
APS twin-vent - DV and BOV - all-in-one. Expensive, but holds pressure and no flutter.
Old Apr 11, 2009 | 04:14 PM
Lvis's Avatar
Josh
can u adjust it so that its 100% or 80% recirculating
Old Apr 11, 2009 | 06:27 PM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
+1 for APS
Old Apr 11, 2009 | 06:29 PM
N3VO's Avatar
keep the stock
