oil flow diagram
Old Apr 20, 2009 | 12:22 PM
nils's Avatar
nice.... I got my 2 quart unit in there this weekend too... workin real good!
out of curiousity... how much air psi u put in it?
Old Apr 20, 2009 | 12:29 PM
jid2's Avatar
I tested with 60 psi for leaks, then dropped the pressure to 10 psi and started the car.
Old Apr 20, 2009 | 12:34 PM
nils's Avatar
only 10 psi?
im runnin it with 40psi
Old Apr 20, 2009 | 12:43 PM
jid2's Avatar
That's right out of the instructions. They say to have it at 5-10 psi when you first start the car to fill it up. At idle - full it reads about 90 psi.
Old Apr 20, 2009 | 01:05 PM
nils's Avatar
yea... mine is at about 90psi full...
Old Jun 30, 2009 | 11:34 AM
smack_evo's Avatar
Originally Posted by jid2
It's 3/8" NPT to -10AN.
I think you can just use the similar plug located on the side.
thanks for this info guys. exactly what i was looking for as i'm about to install mine this weekend.
btw this port is actually 3/8 BSP (british standard pipe) but they are so close pitchwise it should seal ok.
http://www.pegasusautoracing.com/thr...ting-guide.asp
Old Jun 30, 2009 | 01:05 PM
smack_evo's Avatar
oh yeah, how long of a run is it to make it back to the trunk. want to make sure i order enough line.
i'm thinking 20" should cover it fine, yes?
Old Jun 30, 2009 | 03:46 PM
jid2's Avatar
20 feet will do it for sure. I can't remember the exact length but I bought stuff too short on the first try!
Old Jul 1, 2009 | 10:57 AM
CO_VR4's Avatar
Are you guys confident that the two ports in the oil filter housing are interchangable?
FP's oil feed line (from the filter) instructions state that one of the ports is for pre-filter "dirty" oil, and the other is post-filter "clean" oil.
http://store.forcedperformance.net/m...vo_Oil_Install
Are they right or wrong?
Old Jul 1, 2009 | 01:58 PM
jid2's Avatar
I'm not totally sure....
But when I pulled the rear plug it looked like it was a machining access point for creating an "L" shaped passage, and it looked like it went to the other port.
Nils might know for sure....
Old Jun 30, 2010 | 10:55 AM
dragers's Avatar
nice installation,
would it affect pressure that the hose is too long?
Old Jul 11, 2010 | 06:43 AM
jonathanlclark's Avatar
hey guy i need some help ! i have my oil pressure gauge line running straight from one of the empty plugs on the oil filter housing and it keeps breaking off !! is there a better place to hook that sensor to or do you guys know what i should use to hook it because obviously the brass fitting i installed from auto zone isn't working!!
Old Jul 11, 2010 | 06:50 AM
oil pressure line
MDJammin
Feb 10, 2014 08:26 PM
neverendingmods
Lancer Troubleshooting
Aug 7, 2012 10:25 AM
RalliMark
Feb 27, 2012 05:45 AM
Stealthmatt
E85 / Ethanol
May 7, 2011 07:02 PM
Stew
Feb 11, 2010 03:45 PM
