Evo 8 turbo problem
Old Apr 24, 2009 | 07:08 PM
boost_love's Avatar
Evo 8 turbo problem
Hey guys, I can only resort to you guys helping us, since mitsubishi dont know anything.
My friends evo 8, lightly modded was working fine. Its done 35 000km now.
From 1000 - 3000 RPM car seems normal and turbo starts to kick in, straight after 3000 through to 6000 RPM or so, the car shakes violently and turbo makes a fluttering sound.
Its as though the turbo is turning on and off like crazy. It's un drivable.
Will it be ok to see the guys at Ralliart?
What do you think the problem is?
Old Apr 24, 2009 | 07:11 PM
JJLANCER02's Avatar
Maybe it's time for new spark plugs. My was doing the same thing, after I pass 3500 rpm it would flutter. Try that
Old Apr 24, 2009 | 07:17 PM
boost_love's Avatar
shiiite~ thanks dude,
whats the best spark plug I could go for? or do I just go for the factory ones?
and why would the spark plug cause this retarded problem?
Old Apr 24, 2009 | 07:20 PM
JJLANCER02's Avatar
Not enough spark, I use ngk idrium 12-16 dollars per plug I change mine out ever 20k miles
Old Apr 24, 2009 | 07:35 PM
boost_love's Avatar
thanks heaps.
I'll change it now.
Old Apr 24, 2009 | 07:36 PM
eldiablo79's Avatar
The same thing happened to me when the Advance auto store sold me the wrong plugs.
Old Apr 24, 2009 | 08:01 PM
boost_love's Avatar
The owners telling me, he thinks its a waste gate problem.
does that sound right?
Old Apr 24, 2009 | 10:15 PM
sparky's Avatar
Is your mate running the stock recirculating diverter valve, or an aftermarket blow-off-valve?
Old Apr 24, 2009 | 10:24 PM
rolly1818's Avatar
Registered User
i would say plugs, then fuel system (pump gone bad time for a Walbro!)
or a boost leak as sparky said.
Old Apr 24, 2009 | 10:27 PM
sparky's Avatar
Don't spend all that money on fancy Iridium plugs for a lightly modded street Evo 8. An NGK copper core plug such as the BPR7ES, BR7ES, or the BPR8ES would be serviceable. Gap should be adjusted to 0.024-0.026".
Old Apr 24, 2009 | 10:41 PM
sparky's Avatar
The WG is easy enough to check. There have been some isolated cases where the WG flapper valve(wastegate puck) has become unattached from the pivot arm. But, this is indeed a rare occurence.
Otherwise, on the stock WGA, the diaphragm could be torn. This is even a rarer happening. To me it doesn't sound like the usual WG degradation, but I could be wrong. At least the way you describe it, it doesn't sound to me like a wastegate issue.
Old Apr 24, 2009 | 11:03 PM
boost_love's Avatar
Then, I'll replace the spark plugs for now. See what dfference it makes.
Hope it's not the WGA.
Thanks guys. I'll be replacing it on Monday.
Old Apr 24, 2009 | 11:06 PM
sparky's Avatar
Just save me some Brown Ale!
Old Jul 7, 2015 | 02:55 PM
Subieflow775's Avatar
turbo problem
My evo 8 turbo and HKS blow off valve are not functioning and i cant seem to find the problem checked all pipes and spark plugs and nothing
AJ18
Feb 4, 2017 07:16 AM
4g63jdm
May 11, 2016 09:25 AM
Tmigel87
Feb 25, 2016 07:52 AM
evoholic3088
Feb 20, 2016 09:19 AM
zxac
Lancer Troubleshooting
15
Sep 29, 2015 01:04 PM
