Need some help from fellow troubleshooters
Old May 7, 2009 | 04:56 PM
Kainvorador's Avatar
So, i'm driving in the rain, just cruising and doing the speed limit. I get to a stop light and slow down, clutch in, downshift, neutral, stop. Car dies. Right there in traffic. I didn't stall it, it just shut off. Try to start it, and it won't.
I get it pushed off to safe location and start wracking my brain. Battery voltage is good. Turning the key I can hear it crankin, but it's just not firing.
Timing belt isn't very old, I had it replaced not too long ago so I don't think I jumped the belt. Only thing I can think of is its either a fuel problem, or an ignition problem. My walboro wasn't whining overly loud like most do when they go bad.
Any ideas would be helpful.
Old May 7, 2009 | 05:07 PM
vicksen's Avatar
sounds like what happened to me on a couple of rainy occasions. Water seemed to help arc the connection. See if this helps: https://www.evolutionm.net/forums/te...lown-fuse.html
Old May 7, 2009 | 06:22 PM
Hmm...I'll have my mechanic check that out. Thanks for the info, bro.
Old May 7, 2009 | 06:51 PM
Chukee_R's Avatar
This happened to me once, just check your rear o2 sensor. The plastic shielding on my o2 sensor wire was cracking and it exposed the wire, blew my ECU fuse.
Check your fuses.
Old May 8, 2009 | 11:22 AM
Blown #8 fuse. Replaced it and it fires right up. Trying to find a wiring/fuse chart but I'm having difficulty locating one. What all could blow an ECU fuse besides a o2 sensor?
Old May 9, 2009 | 08:51 AM
barneyb's Avatar
https://www.evolutionm.net/forums/in...lins-rain.html
mr06
Oct 19, 2016 10:13 AM
Sharpie0311
Dec 22, 2014 06:16 PM
dethrock
Nov 26, 2014 04:53 PM
neilschelly
Lancer Engine Tech
10
Dec 22, 2012 02:36 PM
baro
Jul 27, 2011 11:41 PM
